Sea urchin shells
Sea urchin shells
Sea urchin shells
Jerry Klug
>I'm not sure if I am experiencing a "senior moment" or not. I have a thought rattling around in my often vacant head that there is a way to increase durability of sea urchin shells for handling of shell based ornaments. Something about soaking or spraying them with a stabilizer (maybe a glue). When I ask other turners about it they haven't heard of it but I keep thinking I came across it some time back. Anybody know if I there is a process or am I just day dreaming and need to get more oxygen.
Re: Sea urchin shells
I won't testify as to your need for ...
Ed Moore in SW Virginia
>oxygen, but at Walmart you will find Krylon Triple Thick Crystal Clear Glaze 0500 in a spray can. Spray several coats inside and out and it should protect the shell from exposure to air. The spray will soak in, so four or five light coats is better than two or three heavy ones.
Ed
Mark Paulley
>Jerry
Ed Moore advised to use Kyrlon Triple Thick glaze on the inside and out side to give a more protective skin from the environment. You kind find where sold on the Krylon web site. I have followed this advise and it works just fine. It will not stop the urchins from busting if dropped but does protect against environment and the shell just breaking down.
Thanks to Ed for this good advice!!!!!!!
Mark
Re: I won't testify as to your need for ...
Michael Stafford
>The Krylon certainly helps to provide a little extra strength but it also helps the shells from picking up stains from dirty hands. For instance when one is turning a finial or icicle for a shell from a really dark dusty wood the dust will not stain the shell as readily.
Be sure to remove all the glue from the sticker that are sometimes on the shells. Shows up like a sore thumb under the glaze....
Lan Brady
>All the proposed solutions will protect it from dirt. If you drop it on concrete, you will not find all the pieces!!!! You are not prtecting it from a fall.
I wonder how Lan knows that!
Good luck, Lan
Doug Turner
>I use some CA thick on the inside seam of Sputnik sea urchin shells. I found that the seams are weak and sometimes separate just from handling. One of the club members stated he used carpenter glue on the inside of urchin shells (which is more flexible than CA).
