Toys & Glue
Toys & Glue
Toys & Glue
Ed Conhaim
>Am making some toys and some of the parts need glueing, mostly where axles attach permanently. The plans call for epoxy. Am wondering about the advantages/disadvantages of epoxy vs CA vs urethane. Would appreciate any info...thanks
Re: Toys & Glue
Re: Toys & Glue
>Epoxy would be among the strongest. Epoxy also has the capability of bridging gaps. Epoxy is also quite visible and doesn't take stains well.
CA can be strong, but I find it somewhat brittle. It doesn't bridge gaps well. It will sometimes take a dye.
Urethane - I think is a poor choice. I personally don't like it.
You haven't mentioned hide glue or yellow glue. I use both and I like them a lot.
Re: Toys & Glue
Richard Allen
Re: Toys & Glue
Richard Allen
>Epoxy? There is a little bit of a learning curve with epoxy. Once you are past that learning curve you will find epoxy has some wonderful qualities which don't exist all together with any other glue.
Flexibility - epoxy remains slightly flexibility which lets it maintain grip under shock and stress.
No-creep - epoxy doesn't creep Flexibility and creep tend to go together so this attribute along makes epoxy unique.
Water proof - cured epoxy is not effected by water
Long open time - actually the open time is controlled by the hardener used.
Very little tack - when epoxy is first applied the surface is very slippery making positioning of the surfaces simple.
Gap filling - epoxy can fill gaps without loss of strength.
Fillers - epoxy takes fillers so that epoxy can be thin as water or thick as toothpaste.
Color - color can be added to epoxy
Food contact safe - properly cured epoxy is safe for contact with food
Structural - epoxy can be used as a structural component
