Sticks and Stones
Sticks and Stones
Sticks and Stones
Bob Way, Canton, MI
>My sons and daughters (�in-law�) went in together and gave me two very nice blocks of Alabaster. I quartered one of the chunks, and turned this vase. Another piece is in the works, and when done both will be re-gifted back to them. I�ve never named any of the pieces I�ve made, but in this case I�m calling this one Siblings #1. It�s 4� in diameter, 6� tall and is made from alabaster, bloodwood, and hard maple. As always, I appreciate you taking the time to look, and enjoy your thoughts and comments.
Bob Way
Canton, MI.
Re: Sticks and Stones
ebd
ebd
>Very very pretty. Nice curves and the wood has a beautiful figure as well. Your kids will love it.
Norm Smith
>Bob,Very well done.
Norm
Cyril Griesbach
>Very nice, Bob. The wood and stone compliment each other very well.
Very nice work, Bob.
GaryG in MD
Barry Elder
>Soon to be a family heirloom, I'm sure! Very nice!!
How did you chuck the alabaster?
Ellis Walentine, Host
>Lovely work, Bob. I've got a chunk of alabaster that I've been meaning to turn, but I can't figure out the best way to hold it. Do you epoxy it to a waste block and mount it on a faceplate? Also, what other advice can you give about tooling, RPMs, etc?
Another Alabaster Question
Barbara Gill, Remlik VA
>I have heard that when you turn alabaster you end up with a gritty talc-like powder all over everything. Is this true?
Re: How did you chuck the alabaster?
Bob Way, Canton, MI
>Thank you, Ellis. You are correct, using epoxy and attaching to a waste block on a faceplate is one way to mount the stone, and works very well for larger, heavier pieces. Another method that I�ve come to like is turning a mounting block that will fit my chuck, and then using turner�s tape to attach the block to the stone. Both methods takes a flat, smooth face on the stone. I use the tailstock help keep it in place. This allows me to rough the stone to basic shape, gives me a little flexibility in determining what will be the top or bottom depending upon what I run into, and will allow attaching a foot or rim with a little less cleanup of the surface. Either mounting method works quite well.
Turning stone is a scraping action, and high-speed steel scrapers will work. They will dull quickly and even though they will continue to cut the stone, the edge will receive a lot of wear. Re-grinding them for wood turning is a major effort. I now use carbide inserts. Square, round, and a bigger triangle shapes. I made a couple of simple tools for these inserts, but I also have a couple of curved hollowing tools that take replaceable steel cutters among my woodturning tools, so I will replace the steel cutters with the carbide inserts on those.
Speed is relatively slow. A lot depends upon the size of the stone. Roughing the initial block is usually around 200 rpms give or take depending upon the feel, intuition, and comfort level you have while roughing. Once round it can be stepped up. I will typically do shaping in the 800 � 1200 rpm range. There are frequent stops to check for cracks. If found, they are treated with thin CA. If you are uncertain whether it�s a crack or not, a little water on the stone will let you know since it will flow into the crack. Speed is slowed done for sanding, which goes very quickly. Step through the grits until you achieve the feel and sheen you like best. The piece I showed was sanded to 4000 and did not have a finish on it at the time of the photo.
I�ve touched on the basics, but would be happy to answer anything I may have overlooked, or needs clarification.
Bob Way
Canton, MI.
Re: Another Alabaster Question
Bob Way, Canton, MI
>Hi Barbara. I have a basement shop and had heard the dust storm and other warnings about the mess. So, I put off trying it for some time. Frankly, I don't think it's too bad. Alabaster creates a very fine, heavy dust. Kind of like powdered sugar. Stone is heavier than wood, so most of it falls straight down. For sure it does cover the banjo, the lathe ways, and anything down below that. That said, though, I do have a dust collector hose behind my lathe, and I position it behind the piece while I'm turning or sanding. That catches a lot of what would go airborne. There is still some that does get airborne and settles on nearby surfaces. I haven't found it drifting to the far reaches like the dust from my wood segmented pieces do. Biggest problem I have is tracking it all over the place on the bottom of my shoes. I have had more than one vocally energetic reminder accompanied by the appropriate body language to change my shoes before coming up from the basement.
Bob Way
Canton, MI.
