how loud is your Gast vacuum pump?
Phil in NJ
>Hi,
I just received my Gast 0522-P335-G509DAX courtesy of SurplusCenter. Wondering how noisy other's pumps are?
I have a small filter/silencer on the output and a bleeder valve / gauge setup on the input.
Mine seems fairly loud... louder than a Festool vacuum, and somewhat rough sounding.
(Yes, I did wire it for 220v :)
Thanks!
-Phil
Re: how loud is your Gast vacuum pump?
Greg Burnard
>I have the same unit from the same source.It's the loudest piece of equipment in the turning shop. Louder than the DC or compressor but I wouldn't want to be without it.
90dB
Ellis Walentine, Host
>I don't know if yours is the same model that I have (1/4HP, 220v, from Surplus Supply), but I just measured the noise with a dB meter and found that it puts out a 90dB racket at the source. My pump is at floor level, though, so the noise at ear level is more like 82dB, theoretically under OSHA guidelines for hearing protection but pretty annoying. I've considered ways to isolate the pump, like suspending it on shock mounts inside a flakeboard box. You'd need to put an extender on the gauge stem and the shutoff valve though.
What's the answer? You could spend many hundreds for a pump like Vacuum Pressing Systems sells. Maybe a decent set of earplugs is the easy way out.
>I have a very old one I bought at the flea mkt. Mine is noticeable. I wouldn't call it loud but it sure isn't quiet. Bobby Clemons has one he bought from Oneway brand new. From about 8 feet away you can't hear it.
I currently have mine on the end of the lathe but I'm moving it to a custom built rolling cabinet that will sit below the end of the lathe. This cabinet will have a cooling fan and the pump will sit inside the box which should quit it down some. I'm also going to put a big drawer in there to hold some of the vacuum chucks and get them out of my other tool cabinet.
Peter Lamb
>You may wish to consider putting as much as six feet of hose on the exhaust side of the filter and maybe even venting it to the outside.
This greatly reduced the noise on my gast.
Peter
Carol - now back in Dubuque, IA
>10-12 years ago I taught a vacuum clamping class in a woodworking program at a community college in California. One 'problem' was that there was little information available, so much experimentation occurred.
Mufflers are your answer. The little brass plug type mufflers are nearly useless. Think glass pack mufflers from the muscle car era. We packed steel wool (not too tightly, not too loose) into a container with holes drilled in it. We ran a hose to that container from the pump and located it low on the pump stands we were building. That was pretty effective.
I can't remember if anyone tried fiberglass insulation. Ought to work.
Containers varied. I used large plastic vitamin bottles. Drilled a hole in the lid to shove the hose into. Duck tape to the rescue to keep it from blowing out. Drilled a series of holes (3/16" or so) around the bottom and in the bottom. Test for back pressure by listening to the pump. If it labors, drill some more holes.
Nowadays I would use one of those larger plastic fruit or mayonnaise jars, quart size or so.
Hope I've been helpful.
Dominic in Bucks County PA
>Phil,
I got the same pump and noticed it's loud as well. When I use it I tend to wear ear protection (ear plugs).
I've had mine now for about 4 or 5 years and it works great despite the noise.
Dominic
Gary Ljostad
>What? I can't here you my Gast vac. pump is running. Great idea about the muffler. I'm going to try it.
I was waiting for that "what?" comment :)
phil in NJ
>Thanks very much everybody! I'll play around with mufflers.
-Phil
For a Little Thing
Barbara Gill, Remlik VA
>it sure is loud. I just wear earmuffs.
Rick Allen
>That is a rotary Vane pump. I have a diaphragm pump and it is quiet, about like a purring cat.
Mike Nelson
>Mine (a Gast from Burden surplus)is probably as loud as yours but it is behind the wall...in my wife's ceramic room, I hardly hear it ;)
Rick
>Could you elaborate? info such as make and source.
Thanks!
Jorge
Mine's 100db
Phil in NJ
>I measured mine... it is 100db up at the pump, 90db 6ft away. Most of the noise is coming from the motor side, not the vane side.
Mike Peace
Mike Peace
>I am glad a bought a used Gast 523 110v off eBay instead of the Surplus Center 522 220v model. It really does not make much noise and I have it mounted on the wall with thick rubber washers. It is only a few feet away from the lathe and just above ear level. It makes far less noise than my HF DC and I do not feel the need for any hearing protection. I have about a foot of hose on the exhaust to help muffle the sound.
Mine is 110
Dave Peebles Lyons, Ohio!
>Hi Phil,
Mine is a 110 that I bought several years ago from the same source.
It was much louder that the pump Oneway sells. I finally put it into a rolling cabinet that really made it much quieter.I covered one side of it with plexiglass, and the other with 1/4" plywood with some vent holes drilled into it. I also added a small computer fan to keep the temps down.
That made it almost silent when I was running it.
Best wishes,
Dave
Keith Tompkins
keith tompkins
>Carol, I would caution against using fiberglass for the muffler; similar to asbestos fibers, the sharp fibers of glass will cause lung damage if they enter the lungs.
Mine is quiet.
Carl Ford
>The Vaccum pump I got from same source is quiet. Just like the one I got from Mcmaster Carr.
You need to have filters on both the input and output with muffler plugs.
The filter on output creates a little back pressure. Makes pump run better.
You may also need to clean the vanes. You can purchase some vane cleaner from Gast.
Details on filters and muffers are at my web site. http://www.carlford.info/assets/demos_classes/vaccum_chucks_demo/Vacuum_Chucks_Demo.pdf
