>Does anyone have any feedback on the Sanding Glove Angle Head Drill? It's a great price and my Milwaukee died this past weekend. I know I can get a replacement bearing, but when I tried it with the last one all I got was frustrated. Thanks in advance.
I got one from them when they were at SWAT and I think it has held up good for my sometimes hobbyist use. It came with two of the sanding arbors and is the only thing I reach for these days for power sanding. As a side note, if you ever have a chance to go to a demo done by Bruce Hoover (the guy at the sanding glove) don't miss it.
>I just bought one last week, as did a friend who was with me. We got the keyless chuck version. I used a loaner that Bruce had for about a month while waiting for some to come in. I also have a Sioux that sounds like it is on it's last legs (bearings?) I consider drills used for sanding to be almost a "disposable" tool since they are operating in an environment that they were not really designed for - running constantly for relatively long periods (as opposed to drilling) with lots of dust. The tool at Sanding Glove is a good bang for the buck and I am happy with it.
>I agree with Carole in that I consider an angle head drill as a disposable item. For that reason I went to HF (Which I am not a big fan of) and bought one of their $25.00 angle head drills. It's not keyless but once I locked the arbor in it doesn't have to come out. When the drill wears out, I'll just throw it away and go get another one.
>I agree with Carol that it might be necessary to consider the angle drills we use as "disposable". Although I still can't bring myself to consider the main drill I use (a Milwaukee "close quarters" drill) as truly 'disposable' given its price, the wood dust, and more importantly, the dust from the abrasives (aluminum oxide) really takes a toll on the moving parts of these tools. I blow out my drills very frequently, and it is still going strong after 7+ years of fairly heavy use. I think I've already gotten my money's worth out of this tool.
A few years ago, I arranged to do a group purchase of some angle drills marketed under the name 'Grip' for our turners group. These drills are blue (instead of 'Milwaukee red'), but appear to have exactly the same plastic housings as my Milwaukee drill (down to the location of screw holes, lines in the plastic body, and remnants of flash marks at the edges). I assume that the Milwaukee drills have better quality "guts" and likely better bearings, but the Grip drills still spin the sanding discs the same as the Milwaukee drill does, as far as I can tell. It doesn't sound as "smooth" as the Milwaukee, but I paid $ 35, not $ 135, for the Grip drill!
I got the Grip angle drills through Overstock.com in a 'bulk' package of 12 drills, and when all was said and done with shipping, etc., the individual cost per drill was about $ 35. To my knowledge these drills perform pretty well for sanding turnings (I haven't gotten any complaints!). Although my main drill for sanding is the Milwaukee, I use a cheapie Grip drill as a second drill with a "permanent" disk extension and disk holder chucked-up; I have two new, unused Grip drills "in inventory" when the first one wears out. At $ 35 apiece, these tools are truly "disposable", although I am philosophically opposed to the 'ungreen' practice of "purchase, play, and pitch".
Alas, I just checked the overstock.com web site, and it seems they no longer list this deal on angle drills (...they had these offered for a LONG time!). I did a quick search on eBay, and the link below is for a seller that is offering the same Grip drill that I use - Total cost is about $ 45 - BTW, I have no affiliation with or knowledge of this seller.
If you come across a Grip drill that looks like the Milwaukee close quarters drill, I can tell you that they do work OK for sanding of turnings on or off the lathe, and this is about as close to a 'useful' disposable power tool that I have come across in over 30 years of woodworking.
>I have 4 of the Sioux/Milwaukee drills. When I ran at higher speeds, full trigger speed, I would get about 300 to 350 bowls before the bearings were shot. I slowed it down to about 600 rpm by putting a piece of 1/4 inch cork under the trigger, and now seem to get about 450 bowls per set of bearings. I bought some fancy bearings, and that really didn't seem to make much difference, but maybe it is time to but a factory one and do a destruction test on it again. I had one of the clone drills. It didn't last a month before the plastic casing failed, not the bearings. That was 50 or so bowls. I have worn out a couple of the casings on the S/M drills. Some one was telling me that Milwaukee now has a 5 year warrantee on their tools, so will have to investigate that as well.
Having heard about right angle drills and their projected life I purchased the HF right angle drill along with the extended warranty(which I never purchase.) My first one lasted 9 months replaced at HF in 2 seconds. Second one (the "free" one) has lasted over 2 years. Now that I said that in print it will most probably die this weekend.
>I purchased the Sanding Glove drill and used it for a while but was disappointed that it did not last very long. It died with minimal use after the warranty expired. I then bought the right angle HF drill for half the price of the Sanding Glove model and it's been going for almost a year now. With all the dust and side pressure on the chuck and gears all these drills will have a short life but as others have said, treat them as disposable like your abrasives. The price is right and they are on sale right now.
Klingspor is a dealer of Grip drills. They had them on sale for $39.99 at Southern States last April and I bought one - the guys at Klinspor told me they were holding up better then Sioux. I've used it heavy for a year, kept it blown out and it is running great. I would buy another and not complain if it died tonight! Don't know if you can get them off the list price if you call but if you see them at a show they should have them much lower then the catalog price. I would call and ask for the Symposium pricing.
>I buy the cheapest angle drill I can get. Even the high price ones don't have sealed bearings. Sanding dust just kills them. Plowing the dust out of the caseing helps but after a while they are ready for the dump.
Now I have a rebuilt drill that I got form Sears about 5 years ago and it is still going like the Bunny. It is not an angle drill though. I expect the bearings are sealed.
Have you looked into air sanders? I am thinking that, my Milwaukee is in its last leg, It seems that they have nothing to go wrong with them, it is just a turbine built to spin and spin.
>My Sioux close quarters drill lasted only two years with moderate use. At it's price that is a big hit. I blew it out fairly often. I bought two Harbor Freight versions, one for a backup. One spit sparks but it was quickly replaced, no hassles. One is into the third year of use, and my backup is lightly used. I notice that the HF version has a long handle with the air intake in the bottom of the handle. The Sioux has the intake at the head. I think this makes a big difference in how much abrasive is absorbed. I have considered wrapping the HF intake at the bottom with a foam filter material, but so far have no cause to do so. The HF drill is a bit heavier and bulkier, but I like it fine. When I have a long extension on it it is easier to control.
>I'm not George, to whom this question was directed, but I have considered using an air powered sander. In theory, it would be great. You can get a random orbital pneumatic sander that is smaller and lighter and should last longer than the electric drills most turners use for power sanding. The practical problem is these pneumatic sanders use more air than the typical home/hobbyist air compressor can deliver. Even if your compressor could power the sander adequately, it would be running almost constantly -- making sanding a fairly noisy proposition.
>I have a Grex ROS and a run of the mill compressor (25 gallon?). The compressor does cycle fairly often but it isn't a big problem. When it kicks on I just the ROS as a passive sander while it cycles. A large 80 gallon one is on my wish list but not at the top of the list.
