Ingenuity and common smarts needed
Mike Nelson
>Hi all, My nephew in Miami wants to build a tree house, problem is he wants to build it on top of a large oak stump. Not only that he wants to hollow out the stump and cut a door in the bottom so the kids can go in and up through a trap door into the tree house! I had a few ideas; cut a groove around outside and split the wood off toward the middle or vice verse. Got to be a way to hollow out a stump without using bugs, or kids coming over with grand-babies to check on your progress! ;) Any and all ideas would be appreciated! Mike
Re: Ingenuity and common smarts needed
Rick Allen
>Cut the stump down, split or cut it lengthwise, hollow each half with chainsaw of adze, cut out door in one of the halves, mount the tree halves to a proper concrete footing you can take it from there.
>I'm not sure how to control where the fire goes but the early indians hollowed canoes using coals. If you could figure out how to control the fire so it will burn down instead of out you could burn right down through. Then use a chainsaw and/or angle grinder to remove the waste.
Steven Antonucci
How big?
Steve Antonucci
>If it was my project, I'd start with the door (to size) and chainsaw it out with a series of plunge cuts at an angle. The Indians used to burn out the insides of canoe, which made it much easier to remove coal than wood. If the tree was quite large, it might take a while, but could be done with relative ease.
I saw a show on Tree Houses once, and they hollowed them with chainsaws, but the trees were logs, not still standing.
Steve
Cool idea, but ...
Ed Moore in SW Virginia
>some rather nasty insects will be attracted to the exposed wood inside the trunk. I wouldn't want my kids playing in there.
Ed
GalenV
>The how big question from Steve needs to be addressed. What is the diameter so you know how much you can take out for kid passage and still have outer wall strength to support the tree house. How big will the door need to be so you know if you are cutting out too much support on one side of tree. So far no idea of how high the stump is to know how much wood is removed.
Rick's idea of just cutting it down and using slabs to use as a facing sounds good but not sure if practical if size unknown.
Re: Cool idea, but ...
Roger
>The insects will not be a problem. They'll probably get eaten by the snakes :-)
Lan Brady
>THis is a really good question.
Using a chainsaw, I would cut a pie shaped wedge (Approximately, 1/4 the circumfrence), from top to bottom of the stump.(Save this piece for later.
Now you have complete access to use the chainsaw to remove all the heart wood from the remaining stump.
Go back to the large piece cut off first. Remove all the heartwood, leaving the bark and sapwood intact.
cross-Cut off the upper portion of this wedge and use it to build the header back into the stump. The bottom portion is now your door. All the bark lines up when the door is closed.
Just a thought, and good luck, Lan
Re: How big?
Mike Nelson
>Thanks Steve, I'm guessing this has to be big enough for kids to go through a small door and up into the tree house, what three ft at least diameter.
Mike Nelson
>Hey Ed , the first thing I told him was to seal the stump with exterior sealer, bark roots and all, really saturate it. The stump is at least 5' high and 3' diameter. I also figure once and if he gets it hollowed out, seal the devil out of the inside!
Mike Nelson
>Now that is beginning to sound interesting Lan, I also like the idea of drilling a hole in the middle, adding charcoal, marsh-mellows, lawn chairs, beer and time ;)
Sounds like a Shop Shot to me
Ellis Walentine, Host
>Did you see those guys on the net turning a bowl that was about fifteen feet in diameter? They had it mounted on the rear axle of a really big tractor. Borrow the tractor and turn it up on its side do that the axle is vertical. Attach a really large forstner bit and Voila, a huge drill press. You might need a crane to raise and lower it.
Or Hire a well driller that drills bored wells. Commonly 2' or more in diameter. Just be sure you sharpen the bucket first. You can get advice on sharpening over on the Quiet Side.
Curly Smith
>Using standing deadwood for any structural purpose is an extremely bad idea. If you've ever cut down a dead tree then you know that it can fail unexpectedly even though it outwardly appears sound. In addition, coating the interior and exterior with sealer doesn't alter the critter pathway from the soil to the ring of dead wood that is destined to be a termite hotel.
The only safe way is to follow Rick's advice - cut the stump down, hollow it however is convenient, and set it on a proper foundation. If it were me, I'd build the "tree house" with a circular entrance and cover it with the tree sections. It's simply not worth the risk of having the stump snap and toss the lawyer neighbor's kids into the Pyrocanthea.
Mike Nelson
>Yes ! I saw that, you could end up sitting in the tractor with a big catch! With my luck we'd end up with a tractor spinning on a tree trunk till it ran out of gas! ;)
Mike Nelson
>You guys are probably right Curly but we sure did some awful brilliant stupid stuff when I was a kid! Had a thought though, how bout notching for 4 2" pipes driven a few ft into the ground being the actual support, hmmm..
