Skip Beardsley, this one's for you.
Gary Evans Tallassee, TN
>Hi Skip,
I saw your post under the Donating Rough Blanks thread and thought I would post a picture of the setup I use for holding half logs to trim into blanks.
All it takes is a good sized log section and a bar or pipe clamp. Take a V shaped cut out of one side, making sure that the upper half of the cut is parallel to the top of the log. If you need to clamp down a half round section, you can run your chainsaw back and forth over the round surface to make a flat spot for the clamp.
I also cut a V in the top of the stand so that I can use it to crosscut or rip the log that I'm making blanks from.
Hope this helps.
Gary
