BowlsSaw My turn on it
JohnKyler
>I finally went out in the shop today for recreational turning to give this a try.
It worked better and easier than I had expected. On one bowl blank I used it on it was dry walnut. This ended up with a little more heat than I had expected. But I was pushing this to see if it might jamb up on me.
I used caution at first, as I didn't want it to ruin my day with the 4224 at 3hp. When I got comfortable, I went ahead and bound it to see what would happen. I know that sounds bad, but I wanted to be able to see what would happen when it jams. The center popped out and all was good. As I know I will be asked by my customers what I thought. Well on my lathe I would not like this to happen often. But on smaller lathes it would likely stop the lathe and not be an issue.
Verdict: I would recommend this for smaller lathes. For a larger lathe I would say other coring systems would likely be better since they have longer handles and tools rests to reduce or prevent tool jamming. I can say it could use a longer handle, that might have a point of reference as to the cutter orientation.I will be marking mine with a sharpie. I would also say it is worth the money, and will save wood as described. In response to some posts that "you can only turn dog dish" bowls. I would say, so what, many do this, like them, and there is nothing wrong with them. Realistically most are not selling their work, so enough said. I do on occasion turn cereal and salad bowls as gifts, and this would work fine for that, and calabash forms are also possible.
So I plan on passing on the info to others as a less expensive way to save wood.
John
