Donating Rough Blanks
Doug Reynolds in Seattle
>My turning club does a wood raffle at each meeting. Usually we have about 20 stacks of wood to pick from. Sometimes I don't have any "logs" as I try to rough turn and seal to reduce cracking. I only have a Jet mini so, my blanks are on the smaller size of 10" diameter. Is it okay to donate a rough turned blank for a club wood raffle? What's you opinion?
Re: Donating Rough Blanks
>I think it's great to donate a rough turned blank, either turned to a cylinder or roughed to a bowl or platter or whatever. Some people with limited access to wood appreciate any wood. Some people may not have a chainsaw and bandsaw and a good way to convert a log section. If you've left it thick enough, there is usually plenty of wood for design creativity. And some people who lack creativity may appreciate the rough-turned guidance towards a form.
When I started woodturning a friend gave me a number of rough-turned pieces which went a long way towards getting me started.
I'm personally on my way to our woodturning club in a few minutes with two tubs of holly, all cut into squares and chunks, some turned round.
>rough turned blanks are fine. The simple way to tell is if no one picks it up. I'll bet they will in a heartbeat. I also try to make my blanks small enough to fit 12" and under lathes because that's what most people have. I do bring in logs because a lot of times I simply don't have time to cut them up but that seriously hampers the new turners who don't necessarily have bandsaws and chainsaws.
Ralph
>Dave Schweitzer donated several to the Bremerton club this fall
Carole Valentine
>By rough turned, do you mean a roughed disk or cylinder, or an actual roughed out bowl? A blank is fine. I would consider a roughed out bowl to be partially turned with the form more or less established by you. Personally, I would not put that in a club raffle, but some people might like it.
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>We have a 50/50 draw at the end of each of our club meetings and I have been donating a bunch of bowl cores as "consolation prizes". As I do not make bowls under 12 inches, these cores are great for people with smaller lathes. I have found they are really appreciated by the winners.
Skip Beardsley------WebKitFormBoundaryo2PSwy+o0IUR
>I couldn't find a place to start a new discussion and my question is somewhat related to this one. I am interested in knowing how others hold or contain log sections which they are processing into bowl blanks. I use a chain saw and have often thought there must be a safer way to hold logs while I cut them.
For small logs I use the band saw, but for larger blanks I half cut the log with the chain saw and then draw a circle on each half. That is the point I start to cut out the blank with the chain saw but don't have a really good way to secure it. NO problems yet with this system but am sure there must be a better way
Ed Conhaim
>Our club, the NJ Woodturners has a raffle at the end of each meeting and there is usually some blanks. As a turner who can not use a chainsaw, the opportunity to acquire turning wood without paying the ebay prices is most appreciated.
"Post New Message"
>Skip,
This would be a great topic in itself. Click on the "Return to Index" link at the top of this page and then click "Post New Message" at the top of the Turning message index page.
To be clear, you might state whether you have a bandsaw. From your message it sounds like you want to prepare the blank using just a chainsaw.
Russ Fairfield
>No problem. I see it done all the time
Chip in Plano
>I picked up a blank that someone cut with a coring system. So the form is basically set but they didn't leave much for a tenon.
At both of the clubs I belong to, some folks just bring a chunk of wood or a log. These are my preferences because then it's up to me to determine the form.
