Jet 1220VS set-up
Jet 1220VS set-up
Jet 1220VS set-up
Ed Moore in SW Virginia
>I thought I would show how I have set up the new lathe for use and demonstrations. First, I removed the original lamp from the back of the headstock. Then I took a piece of 3/4" MDF 19" x 38" and mounted the lathe on the MDF on the stand using 5/16" bolts and knobs (for easy assembly). I removed the clips holding the cord and the plastic holders to wrap the cord when not in use.
In the back there are three 7/8" pieces of dowel secured for holding the chucks. One chuck is on the bed to show the peg. A 3/4" hole was drilled to hold the keyless chuck or any #2 Morse taper. Three thicknesses of MDF were used to elevate the bracket for the Moffat lamp.
I hope to find some clips that will hold the cords and allow them to be secured out of the way.
Ed
Re: Jet 1220VS set-up
Jet 1220VS set-up, front
>As you can see in this picture I put locking casters on the stand. Before placing the MDF and lathe on the stand I mounted a power strip on the vertical and placed the plastic cord holders from the lathe on the side of the vertical.
I drilled a 3/8" hole for the chuck key and put six 1/4" pegs on the right side to keep tools from rolling off. The Thompson 3/8" detail gouge is ready to turn. [grin]
Before I mounted the MDF I took a trim router and a small rounding over bit and hit every edge of the MDF to eliminate sharp edges.
You can see one of the two handles on the ends of the bed of the lathe. Having moved this lathe several times I assure you that those handles are worth their weight in gold. I would rather move this lathe (100 lbs) with those handles than a 1014 (mini, 80 lbs) any time.
I may add a few more touches to this set-up, but I think it will serve well for doing a demo or as a second lathe. One thing it might need is a holder for a plexiglass shield.
Ed
Re: Jet 1220VS set-up, front
Michael Stafford
>Looks great, Ed. It might be easy enough to attach a hardwood strip to the underside of the front of the table with a groove in it sized to hold a piece of plexiglass so that all you would have to do is slip it in the groove and off you go.
Oh, you might need a horn on that rig when you take it on the road...8-))
Bill Noce Northeast Ohio
>Very nice set up Ed. you have given me some ideas forsome things that I can do for my 1220 set up.
Lan Brady
>Ed,
Looks great.
What are the wheels you used?
Lan
Lan, these wheels are ...
>the excellent casters that are carried by Woodcraft. They cost about $16 each. They lock the wheels from turning AND from pivoting. Highly recommended.
Ed
Bill, I am glad that ...
>you find the ideas useful. That is why I posted the pictures. Some of the ideas came from Mark St Leger, as did the MDF, so I don't claim any originality.
I borrowed some urchin ideas from you, so I am happy to return the favor. [grin]
Ed
How about a tuba?
Bob Macgregor
>Looks nice.
A couple of cleats or a channel on the underside of the MDF might help organize/hide the cords.
BOB
Thanks, Bob. I think that ...
>"cleats" is the word I was looking for. They must exist, I just haven't looked for them before.
Ed
GalenV
>Ed
Would like to hear later what you think of the casters as far as holding lathe stable with out of balance piece. If they have soft tread may be as good as soft pad feet. One caster looks like it has a threaded shaft and nut while others do not. Can you clarify why?
Your upper tray now looks better than the one I bolted to lower stand.
I would still keep my saddle to hold the tail stock when removed.
I moved the Jet plastic center holder to the tailstock end as it already has tapped holes there. Found it easier to reach than over headstock.
Thanks for posting as it gave me more ideas.
I need a mini version of the Roomba vacuum to run around on tray to keep it clean!
Galen
About the light
Atwerz
>I couldn't see much use for the light either. It's just not long enough to shine on the tailstock side. I'm going to remove mine to, it's just in the way.
Re: Thanks, Bob. I think that ...
Bob Macgregor
>You could always make some wooden ones!
Galen, you have good eyes. When ...
>I was attaching the casters one of the welded nuts broke off. So I used a longer bolt and another nut, but kept the welded nut on for spacing purposes. There doesn't seem to be a problem.
I have had this style caster on my Oneway 1018 for over a year and have had no problem with the casters. They are probably soft, they don't slide and I have had no balance problems. We have them on the Jet 1642 at SMLW and they have been fine there. They do add height, so shorter folks need to take that into account when setting up the stand.
I thought about where I put the accessory holder and chose the headstock because it seems more out of the way there.
I left space beneath the lathe and to the right to place tools. I prefer to let them lie down and prefer not to have them in holes on the upper level. Now a saddle with slots over the crossbar would probably work for tools.
Ed
