organizing turning blanks
>A mention of organizing turning wood in another thread made me think of describing what I found works best for me. If there was a Wood Collecter's Anonymous I'd have to go to the meetings. I love to have a variety of wood within reach for whatever project strikes my fancy. This can be a huge problem in a small shop.
Several years ago I started storing turning blanks in these 10 gallon plastic tubs. For a while, I stacked these tubs on the floor which was a bug mess. Now I put the tubs on commercial wire shelves. The tops of the tubs are open to allow air circulation. It seems to work well for drying small green blanks without problems with fungus and cracking from drying too fast.
Each shelf unit is on casters, 4'x18" and over 6' high. I fit three of these shelves into a 5'x8' niche at the back of a one-car garage shop. The shelves are adjustable so I leave room for some loose blocks as well, mostly overflow or those too big or long to fit into the tubs. I have 46 tubs and a hundred or so loose blocks in this spot as well as room for some boards and slabs.
The tubs are mostly organized and labeled by species and age, with a few for "Spalted", "Unknown", and "Misc" where I don't have enough of one type to fill a tub. These are all relatively small pieces of local species - I store the exotics and larger blanks on shelves in another spot. The barn and an outbuilding has the overflow and the bigger stuff.
The plastic tubs are only $3-$4 each and make also wonderful containers for blocks and scrap when cutting blanks at the bandsaw, and with the lids can keep green wood wet as needed.
I've tried larger tubs and they get too heavy when full of wood. The 10 gallon size is just about perfect for me.
