200+ woodworking book reviews
Linden?
Linden?
Linden?
Cyril Griesbach
>I have a nice piece of Linden I got from Harold Fleming last fall. I've never turned Linden and I'm unfamiliar with it. Can anyone give me some information on what to expect from this? The piece is about 13"D x 3"H, round and seems to have had the outside coated.
Thanks.
Re: Linden?
Re: Linden?
>Around here it's refered to as Basswood. Very plain with almost no texture. It is the preferred wood of many carvers because it cuts very clean and easily. I have carved some of it and turned very little, although I have 3 longs laying against the workshop right now. I need to get out there and cut them up.
I don't remember much about the turnings I did, I guess because it was nothing unusual. I turned clean and easily like walnut or soft maple. I believe I made an ornament from it and did some routed inlay's. It accepts woodburning really well. I've used it more for that than anything.
Re: Linden?
Linden/Basswood = good
Allen Neighbors
>Linden wood is good for making utility bowls -- nothing fancy, just really lightweight and very useable.
Re: Linden?
If it is Basswood, then it Turns well..
jake Niedling
>I find it cuts clean with sharp tools and it is light weight. I turn some snowmen christmas ornaments out of it and a few fishing lures.
Re: Linden?
Re: Linden?
John Roth
>I turn basswood all the time for my chip carvings. One caution, though, it finishes horrible unless pre-treated properly. If you plan to add stain, apply a thinned (50-50) pre-coat of polyurethane satin varnish, wipe off any standing finish, and let dry. Then, use gel stain, which is polyurethane-based. Over that you can apply most any kind of finish coating. When I am going to carve a piece, though, I hardly ever use stain.
