Jet JWL-1220VS arrived ...
Ed Moore in SW Virginia
>and it is on its Jet stand, ready to turn something. As has been mentioned, the light that comes with it is too short to be of value. So, I removed the light.
If you order this lathe and decide to remove the light, then I have two suggestions:
1. Remove it before you mount the variable speed box on the end.
2. Remove it before you put the lathe on a stand.
Following the lead of my friend Mark St Leger, I am going to put a piece of MDF that he gave me between the lathe and the stand that will extend back several inches, allowing for tool holes and an arm to mount my Moffat lamp. I have mounted a power strip on the stand, but may replace it with one which has a longer cord. The strip is very convenient for sanding with a drill. The locking casters will allow the lathe to be moved easily.
The lathe runs smoothly and quietly, so I am looking forward to using it. I just hope that the 3/4 HP motor is sufficient.
Ed
