References to temperatures
Jim Pugh, Elyria, OH
>I hope that most folks realize our Canadian brethren are speaking about Celsius temperatures while those of us in the states are speaking farenheit. There is a bit of a difference.
Re: References to temperatures
bill Crommett
>NOT AT FORTY BELOW.
Jesper, Denmark
Re: Correct(ions)...............
Jesper, Denmark
>At -40, both �C and �F are the same.
It's not just the Canadian brethren who are using Celsius, the rest of the World is too.
Fog Tanner
>Its interesting that all the years in chemistry it was always centigrade, and still is for some of us when referring to temp in C and not F...... have never figured out how it changed.
Bill Blasic
Bill Blasic
>Well I guess we'll have to add that one to the list of why the rest of the world hates us :>))
The name was changed decades ago from centigrade to celsius by international agreement to minimize language confusion and provide worldwide consistency in the scientific community. Unfortunately, some people (including textbook writers) are a little slow to catch on.
BTW, besides convention, the Fahrenheit scale persists away from the test tube because it is arguable more useful when people think about the weather. Zero to 100 F nicely describes the range of very cold to very hot weather typical for humans in temperate regions. It's all what you are used to, but pity the poor guys that use C and have to deal with, what, -18 to 38?
In photography all I know is 68F or 21 C
Brad Vietje
I think the joke's on (the) US
Brad Vietje
>Well, yeah, but 0 C = freezing point of water, and 100 C = boiling point... a very logical system, indeed. The Fahrenheit scale was originally based on system that assigned 100 as an arbitrary number representing the hottest human body temp, which seems a bit random to me. Then there's dealing with weird measures with a mix of feet, inches and fractions, etc...
The difficulty is in converting, or translating between the systems, and not in the use of them. Having spent years in science labs using nothing but metric, then going home to a quaint and quirky system yards and feet and pints and ounces (for both volume and weight -- which isn't really the same as mass) I can say that for me, the metric system is infinitely superior. Since all the basic units are handled in base 10, adding, subtracting, multiplying and dividing any metric measure is many, many times easier than dealing with the length of some egotistical and long-dead king's freakin' foot.
Since we are the ONLY major industrialized nation on the planet that doesn't use the MKS Metric system, maybe the joke's really on us?
Safe spinning,
Brad Vietje
Re:Temprature scales
Mark Trulock
>Hi
A German coworker said that the Fahrenheit scale was not totally scientific. He said that the creator used the coldest day one winter to set the scale at 0. Do any of you scientific folk know if he is pulling my chain?
Thanks
Mark
Re: I think the joke's on (the) US
>However, for woodworking I use both. It's much easier to divide 3/4" in half, it's 3/8" half of 1/4 is 1/8. Metric can be harder for things like that. However when I'm trying to find the center of a log I find it easier to use metric.
Coyne
>Does that make you 'bilingual'? :)
Coyne
Zero (0) degrees in Kentucky This Morning!
Barry Turner
>Brrrrrrrrrrrrrrrrr!
It's as close as I get to bilingual
will you be at the TAW symposium nex week?
Doesn't matter...It's still D**N cold!!!
keith zimmerman, Normal IL
Jesper, Denmark
Jesper, Denmark
>I would have thought that chemistry would use Kelvin, not �C - it is so much easier when correcting for volumes and thngs at different temperatures.
Jesper, Denmark
Re: Hate?......Noooh...Cute and olfashioned mebbe!
Jesper, Denmark
Re: Doesn't matter...It's still D**N cold!!!
Lan Brady
>LOL, I agree with Keith
Bob Macgregor
>This is cut 'n pasted from a Wikipedia page. It looks like Fahrenheit also saw the advantages of 1/2, 1/4, 1/8, 1/16, etc (see the last sentence, below).
"According to Fahrenheit himself in an article he wrote in 1724,[2] his scale is based on three reference points of temperature. The zero point is determined by placing the thermometer in a mixture of ice, water, and ammonium chloride, a salt. This is a type of frigorific mixture. The mixture automatically stabilizes its temperature at 0 �F. He then put an alcohol or mercury thermometer into the mixture and let the liquid in the thermometer descend to its lowest point. The second point is the 32 degree found by putting the thermometer in still water as ice is just forming on the surface.[3] The third point, the 96 degree, was the level of the liquid in the thermometer when held in the mouth or under the armpit. Fahrenheit noted that, using this scale, mercury boils at around 600 degrees.
Later, work by other scientists observed that water boils about 180 degrees higher than the freezing point and decided to redefine the degree slightly to make it exactly 180 degrees higher.[2] It is for this reason that normal body temperature is 98.6 on the revised scale (whereas it was 96 on Fahrenheit's original scale).[4]
According to a letter Fahrenheit wrote to his friend Herman Boerhaave,[5] his scale built on the work of Ole R�mer, whom he had met earlier. In R�mer�s scale, the two fixed reference points are that brine also freezes at 0 degrees and water boils at 60 degrees. He observed that, on this scale, water freezes at 7.5 degrees. Fahrenheit multiplied each value by four in order to eliminate the fractions and increase the granularity of the scale (resulting in 30 and 240 degrees). He then re-calibrated his scale between the freezing point of water and normal human body temperature (which he observed to be 96 degrees); he adjusted the scale so that the melting point of ice would be 32 degrees, so that 64 intervals would separate the two, allowing him to mark degree lines on his instruments by simply bisecting the interval six times (since 64 is 2 to the sixth power)."
Bob Macgregor
>Brad, it is even worse than you think. In Canada a lot of folks still insist on using mile, pounds and English volume measures. I'm pretty sure that Canadian miles and pounds(the weight measure, I mean) are the same as in the US. However, the volume measurements aren't. When they quote MPG for a car, it seems high because a gallon is about 20% bigger here than in the US. I had a similar problem at work years ago trying to figure out whether an instrument we had purchased was based on US bushels or English (Winchester) bushels.
I make every effort to use the metric system so everybody knows what I'm talking about.
BOB
>>...coldest day one winter
Mark,
That's what some history books report. Others report the zero temperature is a a certain salt/water solution.
Re: In photography all I know is 68F or 21 C
>Did you get a color cast on your prints? 68F is actually 20C [(68-32)*5/9 = 20]
G,D, & R
Re:Spent my whole life measuring metric inches.
Al Crandall
>I guess it just depends where you work as to what and how you measure things. From 1963 to this very day my work has involved inches divided into thousandths and occasionlally ten-thousandths, which is base 10 inches or metric inches. The print might be dimensioned at 270.625 inches. Never once did I see a yard or foot value even tho 270 inches contains several of both. People toss around the term "metric" when they probably mean "meters", or some tenth or hundredth portion of a meter.
bill Crommett
>Fog: It must have been the same group of idiots who decided to change cycles per second into Hertz. The lesson: Don't let a power group get the upper hand or they will try to immortalize themselves. Like making the UP arrow on a computer point Down.
Re: Metric Inches?- Decimal Inches
GalenV
