>The shop was just above freezing today. I'm going to run the heater in there tonight and tomorrow to keep it above freezing. I have a chemical cabinet that keeps a lot of paints and chemistry from freezing but it isn't large enough to handle them all. I still have some gallon and quart size paint cans that I would prefer not to lose.
When the temp is this low my heaters will only keep the shop at about 40. Too cold for this southern boy to work for more than a few minutes.
>I spent a few hours in my garage shop. About 1/2 before I turned on a little propane heater I got from Northern Tool. It has two ceramic elements and a fan for both radiant and forced air and connects to a propane tank I have outside. After 30 minutes the lathe half of the garage was plenty warm to work. The heater was about $100, another $25 for the long hose and such.
Of course, this time of year I wear longjohns, insulated Carhart overalls, and a flannel shirt.
The house is toasty with the woodburning stove. My woodshed is getting roomier inside, though.
>I'm looking to up grade my propane heater. I may be able to get a 100lb tank really cheap so I'm looking to get a heater that somehow warms me better. More BTU's or better radiant heat.
>in Childress this morning. It was 25 when I finally went to the shop and built a fire. Pot belly stove 10 feet from the lathe, and still couldn't get it warm enough to be comfortable. Kept the fire stoked all day, and I'll bet it wasn't 45 when I quit this evening for chow.
It's 10:30PM and it's back down to 21 outside now.
>Just came in and it is in the 50's outside. I was rearranging my shop and was comfortable without my thermal gear - it was around 70 in there. If it had dropped into the 60's then it was time for the insulated stuff.
If I was meant to be cold I would have been born in Dallas. I think we had our annual three days of winter the other night when it dipped into the 30's. But, according to the Texas legislature those were supposed to come on Friday - so it may still get two more days when it drops down to 35-36 overnight. Be glad when Feburary and Spring gets here...
>Haven't been down in the shop for a week due to a having a very bad cold. So the heat hasn't been on and this morning it is -6 F and I have a new low for my shop 40 F. I turned the heat on and since this cold wave is not supposed to break till Saturday I think I leave it on for a day or two and maybe go down and turn a little.
>I forgot to turn the heater on last night so I went out at 5 this morning. It was 2 outside and right at 32 in the shop. Near the walls it's 28. I know there wasn't a vapor barrier put up in the shop and part of 2 walls doesn't have insulation. It will be a pain to fix that because I have to remove everything I put on those walls and the panels were nailed up using a nail gun. I had to remove part of one of the walls to run more electricity and it was really tough getting the nails out.
Me too ! I have no insulation and no heat near my lathe, and it's -25(F) this morning!
I end up dealing with a lot of insulation issues in the solar biz.
Any way you can drill some 3" holes and get someone to blow in some dense-pack cellulose? When interior disruption is difficult, some people find it easier, and more effective, to do a "wrap & strap", and actually remove the siding from the outside, fill the cavities as best you can, then wrap the exterior with a rigid foam board, which also helps to eliminate the thermal bridging through the studs (which matters less in a shop than a home. I'm sure even fiberglass will help, though I don't think its a good insulation choice at all.
Vapor barriers are a whole 'nuther kettle of fish, are more complicated than most of us ever thought, and the subject of ongoing debate among thermal envelope experts. I'd check with a highly-regarded remodeler or insulator to see what has worked well after years of use in your local climate. I find it a confusing issue, and all I know for sure is that the placement of a vapor barrier depends on your climate, as well as the structure of the envelope. It depends on the temperature and humidity cycles in your area, which might be quite different than somewhere else.
My shop is under all that snow in my ugly barn (taken last winter before I went up on snow shoes and shoveled off the entire roof) -- just a little something for those suffering at 70 degrees!
>I got this on advice from another woodturner and since found two others who use one. I place it on a table about 8' away, aimed at where I stand at the lathe. After heating the room for a while on high, I turn it down to medium or low and I can feel the radiant heat while working. It needs no clearance at the back and just 6" on each side. D-cells can drive the fan but I bought the optional AC adapter. It's made to use small disposable cylinders but they would not last long and would be expensive to operate. I got the 12' hose and connect to a 20 lb cylinder outside by running the hose under the garage door. They claim up to 100 hours on one tank, but that's probably running on low. I have a full large cylinder outside the garage so I may switch to using that.
I found it a LOT cheaper to operate than my kerosene heater since kerosene fuel is so unreasonably high. In addition, it doesn't need the floor space and clearance of the kerosene heater.
Note that 40% of my garage walls and ceiling are protected by the house and I did insulate the rest a few years ago. Not sure how well it would work in a completely uninsulated area.
The rating is 4000-18000 BTU.
Model MH18B
I think it's still on sale at Northern Tool. You can read some reviews in the link below.
>Yeah, it's cold as far as we are concerned (teens and single digits), but at least we don't have to live in a house that Mother Nature has turned into an igloo! No wonder you guys have "Mud Season" instead of Spring!
I would miss 4 real seasons with snow, but escaping to a warm climate seems pretty attractive, too.
BTW: Spring does not start in February around here. We often get a solid week clear and cold (below zero at night) around mid-February. The photos of my barn and house I posted under John Lucas' thread about too cold to turn, were taken in mid-March last year, but the huge snow piles around the house looked like that well into early April!. Two weeks later, we were finding ticks while working on our Apple trees!
