Buffing Question
Buffing Question
Buffing Question
Ray Binnicker
>Ok, I broke down and bought the Beall Buffing system. Looks simple enough. Question is: What is ideal speed ? Also, I am planning on using (initially) Waterlox or Minwax Antique oil. Any other concoctions I need to consider? All advice is welcome.
TIA
Ray Binnicker
Re: Buffing Question
John Weeks
>About 1800 rpm for the speed.
Jack Savona
>I'd suggest you number or ID the side of each wheel until you get used to their feel and look because you don't want to mix the compounds and/or wax. If you're using a morse taper for mounting you'll find you need a draw bar to keep the mandrel from drifting out.
Try buffing both BEFORE, as well as after, you apply the finish. On some pieces you might not even want to apply a finish. Also make sure any finish cures well before buffing or you risk buffing it off.
Finally I encourage you to wear a respirator and/or use your DC. When you buff the very first time, you'll see lint and fibers all over the place. Later on they'll be wood and shop dust and ultra-fine compound dust in the air. You don't want to get that in your lungs.
I know you'll enjoy your finished work even more now. Good luck with your new toy....er...tool.
Jack
Ray Binnicker
>Thanks Jack,
I failed to mention I got the system with the mandrel. I don't know if that poses a problem with all 3 wheels on the lathe at the same time. Maybe another question?
Ray
Re: Buffing Question too - Ray
GalenV
>Did you get the 8" wood buff kit with the motor adapter?
Spare 1/3 hp 1725 rpm motor I have cannot be wired for counterclockwise, so guess it will unscrew buff wheels?
Motor mount appears to provide best flexability and clearance but I would need to add new motor. Used motor still may be better than lathe mount?
Did you get the #2 taper adapter for lathe use and if so seems the wheel would mount close to headstock and cut clearances around. Would this be a worry if you or I do?
Trying to just chuck the motor adapter on the lathe may make the chuck in the way on a bowl and not sure if outside of adapter is true to tap hole anyway. Would this work without buying #2 taper adapter?
Three on a mandrel kit just seems to much material for Jet 1220 and wonder if wheel to wheel space is too close for good use?
Figure you have thought about some of these and can tell me what you think with parts in your hand? Or from others who reply to you.
Thanks Galen
Ray Binnicker
>Hey Galen
The system I got contained 3 wheels, 1 mandrel for mounting the 3 wheels, with the mandrel W/#2 MT fitting in the head stock and the tailstock coming up on the other end, and the 3 sticks of "stuff". I'm assuming the good folks at Beall wouldn't build this thing to hold all 3 wheels at one time if they didn't feel they could be used efficiently. I will find out tomorrow ! I do intend to be cautious with the dust factor.
Thanks again.
Ray
Toney Robertson
>It would seem that the three wheel method would be great for small pieces but I have had some pieces that were hard to buff with a single wheel.
Toney
>I often hear people say that they use the beal system with no finish. Although this can make the wood look great it has a very short life. Carnauba wax is the only finish left behind and it isn't very protective. I urge you to apply some sort of finish first. Let it harden completely(some finishes take a few days to really harden) and then buff it.
Eric Knutsen
>I've used the Beall system for about a year now. No problems with all 3 on the mandrel at once. Without overstating the obvious, it's really only good for doing the exterior of your turnings, unless of course it's a platter. Beall makes "bowl buffs" but from what I've been told they don't spin fast enough to create a nice sheen on the insides of bowls.
Cyril Griesbach
>Eric, I use the bowl buffs and they spin as fast as the lathe does.
>I don't think you need speed. I buff pretty slow. It's just an abrasive. Speed changes how it works but not if it works.
Re: Buffing Question-Galen
bill Crommett
>Taper adapters are available in both right and left hand threads, so buy a new motor to get the right kind of rotation.
Dave Anderson (PacNW)
>increasing speed increases the firmness of the buffs
>>...beal system with no finish. Although this can make
What about exotics like cocobolo? Someone told me buffing is all they do to cocobolo bottlestoppers.
>It does indeed. I use both slow and high speed to my advantage. When you have to get an edge of the buff into a tight area I run the speed up which of course stiffens the wheel. sometimes it's better running slow because the softer wheel will wrap around some details.
Re: Buffing - Ray
GalenV
>Ray
Only buffing I have done in the past was on metal and you used more pressure and abrasive. I did find a Beall video and he did stress it only takes light pressure and little compound. Long spindle to mount all three probably should not be big stress. I guess you learn by observation of spindle for indication of too much pressure.
I wondered if you use 8" disc on a 12" swing lathe if it gives you room to work thinking you use about a 7 or 8 oclock position.
Not sure what swing your lathe has.
I guess I read too many bad things about flying turnings when pulled from your hand. Was sure easy to happen on wire brush on small pieces of metal!
Good luck and may your turnings have a new radiant glow.
Galen
I Converted My 3 Wheel System
Charlie Anderson
>Because of the limitations on the size of bowl that could be buffed, I bought bolts, washers and nuts and converted them to single buffs.
I also bought an 8" extension which screws on my lathe's spindle. The other end of the extension is made for a 3/8" bolt to screw into it.
Getting the buffs centered is tough and mine aren't perfect but they work.
I bought the extension at the AAW Symposium in Louisville but I don't remember from whom I bought it.
Ray, I have a picture tutorial...
Allen Neighbors
>on how I made my own buffing system. You might be able to adapt your present Beall system to work on a regular electric motor. Mounted on the lathe, it might limit the size of pieces you can buff.
I bought an extended mandrel to mount on a 5/8" motorshaft, and it works like a charm to buff everything from 18" bowls down.
If you'd like a copy of the pdf, email me. That goes for anyone. Just remove the REMOVE.
Re: I Converted My 3 Wheel System
>Frank Penta showed how to make a useful extension for the Beall. He turns a 2"x8" cylinder, recesses the working end a bit, then drills a hole and screws in a threaded insert (from Lowes) to hold the Beall bolt. He holds this cylinder in a chuck for buffing.
I ended up mounting each wheel on it's own MT spindle. This makes changing wheels extremely quick, is great for the small things I like to do, and gives plenty of clearance to get inside large bowls. The wood extension would be better for large platters.
Roger Dunn
Don Pencil system
Roger Dunn
>I got Don's system and run it with an 8 inch extension on the outboard side of the headstock. It turns clockwise and that took a little getting used to. It works fine with plenty of room to maneuver the bowl and my body around the bowl buffs and larger wheels. Changing wheels or buffs is quick and easy. Most of the bowls I turn are larger than 12". I think it is cheaper than the Beall system too.
Good luck.
