Re: Not clear on the Hunter Tool pricing - or whic
Michael Stafford
>Jerome, I think your decision will be dependent on how you intend to use the tool.
I have not used a #6 so all my comments regarding it are hearsay. My understanding is that the #6 was developed for turning bowls as an alternative to using bowl scrapers and whatnot. It can be used to great effect in hollowing a bowl I believe also. Now, like I said, I have not used the #6 but it seems to me the cutter could be too large for hollowing on the inside of turnings. The Hunter works so well because only a small portion of the diameter of the extremely sharp carbide cutter is in contact with the wood at a time. Thus the larger #6 would work well in a bowl type situation where you can control the cut visually.
When I am hollowing on the inside of an object I am not able to control how much of the cutter diameter is in contact with the wood at all times. If the Hunter has a large amount of its diameter in contact with the wood at one time it chatters and cutting performance decreases. So a smaller cutter is more forgiving and does not create the huge amounts of torque that a larger cutter would create when the cutter is cutting over a large part of its diameter. In other words the big cutter yields big dig ins when too much of its surface is cutting at one time.
The #5 uses a smaller cutter (3/8") and is mounted on a tapered shaft so you get the benefit of extended reach over the tool rest without tool chatter and better control because the smaller cutter takes a smaller "bite". It works very well on the inside of smaller objects.
If anyone has a different explanation or a better explanation please jump in and help me explain.
Mike Hunter, where are you when I need you, buddy? 8-)
