O/T Shims
O/T Shims
O/T Shims
Tom Vensel
>Hi Folks , I'm off topic but I need to make a handfull of thin hardwood shims about 3" wide .I know I have seen a method to make them in a woodworking mag but I can't find it know .Can anyone help ? Thanks in advance . Tom in S/E Ohio
Re: O/T Shims
Re: O/T Shims
Ken Grunke from SW WI
>I use my electric miter saw (chop saw) with the blade set to 2 or 3 degrees, to cut a short piece of 2 x 6, about 4-5" long, into wedge-shaped shims. I only have a 10" saw but a 12" blade ought to be able to cut 3" wide shims if you have a saw that size.
Set the blade to half the desired angle of the shim, and flip the piece for each cut. A coarse-tooth ripping blade would make it easiest.
