Depth drill
MFoster
>I have just completed one of my larger projects that seems to take over the shop. It is a large segmented form which I posted pics of on both WOW and AAW. Wont bore you all with that. I took a day to clean up the shop and make the tools find their homes. In the process I decided to make some tweaks to jigs, and do a little more organizing. One of the things I did is sharpen a 3/8 drill that I use for a depth gauge. Even after sharpening I find that drilling into endgrain, it still want to wander off of true and winds up wobbling pretty significantly, and the hole winds up far from true center of the stock. I have a "D" drill that I made from drill rod and it does seek drill the true center but requires a start with the tailstock. It also takes longer and gets hotter. I have seen some of the pros use a drill with a handle for this function and thought I would make a handle for my drill, but with it wandering so much, not sure I want to. How do they do it?
What is your experience with the hand held drills used as a depth gauge??
