Cutting tip and Laser alignment
Sean Troy
>Are there any changes in accuracy with the cutting tip angle changed from one point to another as long as the laser is adjusted to the same distance with each change of angle?
Sean Troy
Re: Cutting tip and Laser alignment
Allen Neighbors
>As far as I know there isn't, normally, But. You have to just make sure that the laser is adjusted to the same relationship to the actual part of the cutting edge that will be doing the cutting. i.e., if you have a 1/4" cutter with a fingernail grind, and are cutting with one certain part of the cutter near the top of the piece, you may be cutting with a different part of the cutter when cutting at the bottom. The laser has to be adjusted accordingly.
Does this make sense to you?
>I agree with Allen. I use a quarter sized rare earth magnet that I drew marks on, to adjust my lazar. I just put the magnet on the cutter and align the zero mark with the tip. Then I twist it until the marks are perpendicular to the cut I plan to make.
I would take a photo but I apparently lost it and had to do the last piece by guesswork. I can make another one if you need a photo. I simply painted one side of the magnet white and drew ruler type marks on it for 1/16" increments and drew a line extending from the 0 point out to the edge to help me aling the lazer perpendicular to the expected cut.
Sean Troy
>I think I would have less chance of error with a smaller tip (3/16) is what I normally use unless rough turning a larger hollow form and then I'll use the 1/4. thanks guys
Cyril Griesbach
>Sean, a smaller cutter will give you only a smaller error but still the same error that Allen describes. He's got it right.
Sean Troy
>I agree, but less is better. :)
Dick Hines
>Maybe Lyle Jamieson will read your post. If there is anyone who can answer your question I bet he can.
Lyle Jamieson
>You all have the right idea. The key is to keep the gap perpendicular to the wall surface you are cutting/measuring. That means the gap runs from where the cutting action is happening on whatever cutter you use out to the laser. The size or position of the swivel and cutter will make no difference in accuracy if the above is done. Great question and a must understand topic to use the laser correctly. Tough to put into words. John, I like your magnet idea. Lyle
Texian
>Dandy idea John. I clamp the boring bar (near end of the tool bit) to the toolrest with a cheap plastic clamp to keep the bar from moving while I fiddle with the laser. Also have a small piece of white paper clamped between the bar and tool rest as the laser target. Have just eyeballed the distance from tool bit tip to laser spot, and never thought of drawing a scale on on the paper. Thanks for the idea.
