>I had to replace the tailstock quill on my Jet 1236 lathe. I've installed the new quill but I cannot seem to get the quill to extend when turning the tailstock handle without actually pulling on the quill. Then the threads seem to want to advance it outward. I'm assuming I screwed up something when putting it in. Any thoughts?
>If the 1236 is like the 1220 I guess you could have the stop lever screwed out so far it will not ride in the keyway. This keeps the spindle from rotating with the screw. If things are loose enough or oiled well the spindle will just turn and not advance. By holding the spindle you keep it from turning and it will advance.
I haven't been inside mine for a few years, but I remember there is an "E" ring that snaps into a machined detent groove on the quill that pushes against the inner surface of the casting at the back end. This ring is the only thing the forces act against to create the forward motion, so it has to be in there for the quill to advance.
This is also a serious design flaw, in my view, since all forces are against this little ring, which causes the ring to bend and wear over time. There is no matching bronze washer or bushing for this ring to wear against, so if you use the lathe hard and long enough -- especially if you turn heavy, wet wood requiring a little more force with the tailstock, the abrasion between this ring and the casting can, over time, drill a nice cylindrical hole right through the back of the tailstock, and burst through with disastrous results when you least welcome it (DAMHIKT!).
If you have the ring in place and things still aren't working, then I'm stumped.
>Ah Ha! That may be it... I remember seeing that little clip and remembering wnat it bitch it was to reset it. I bet that's the case. I'm heading back in to the shop to investigate.... I'll report back later. Thanks.
>Brad, thanks for the insight.... that was the problem. The damn C clip. It jumped out of the groove and wandered up the threads. I reset it. Let's hope it stays....
