Re: Asian ebony box...
Michael Stafford
>Barbara, it is hardly any different than what one would do with a rough out for a bowl.
Start with a box in mind and cut a blank appropriately sized.
Mount between centers and put tenons on each end and part following the proportions for the box you wish to make. Obviously you should have a little extra length so you can clean up the end.
Mount the piece designated for the lid in your chuck and face it off removing as little wood as possible. Then roughly hollow leaving at least 3 times the thickness in both the diameter and lid thickness as your design requires.
Do the same thing for the blank that will become the body of the box except make sure you don't hollow so much that you will have insufficient wood to cut the flange for the lid to fit on. (It does not happen often but occasionally a piece of wood will go oval in a big way. Terry Quiram had Keith Zimmermann deliver some amazing quilted/blister maple to me in Richmond and I got to keep most of it as long as I made a box for him. I followed my normal procedure and to my shock the wood became so oval that I was unable to form a flange on the body to fit the lid. I don't know why this happened but I am assuming it was because of the extreme figure in the wood.)
Take the two pieces and label the ends and throw them in the alcohol bucket and leave them for a day or two.
Take them out. Let them drip dry and tape the closed ends together and let them dry. After a week or two I take them in the house and sit them on the shelf above the water heater and let them dry. I usually let them dry there for a couple of months. If I am lucky the wood will get down to about 12% which is about normal for here. When I take the wood back out to the shop I am not in any big rush to use it because it needs to equilibrate to the conditions out there.
Hope this helps.
