carved cherry vase
carved cherry vase
carved cherry vase
>I finally finished this vase. I replaced the gold Rub-n-buff with gold leaf. It looks a lot better. There are still a lot of things I would do if I do it again.
Because of the way I recessed the carved part it makes it look like it has a second foot to stand on. At least from this angle. I think I would eliminate the real foot.
I'm not happy with the texture I chose for the gold leaf portion. I think it needs to be quite different from the other texture. I used the same dremel engraver but I put a fine point on it to give the gold area a finer detail. I don't like it but the wood is too thin at this point to go back and sand it off to start over.
The outside I'm fairly pleased with, but I carved it with a rotary carver and didn't have as much control over the shapes as I would have with a hand held carving tool. I'll have to practice more with my gouge to achieve these kinds of cuts. It's too easy to get tearout so I was afraid to use it.
Re: carved cherry vase
Re: carved cherry vase side view
>This shows how I thought the foot would look, and of course it does from this side.
That is pretty cool!
Michael Stafford
>I think this looks great. I have to ask a couple of questions. In the section where you removed a lot of wood to establish a new layer; how long did it take to carve out all that wood?
And how long did the entire carving job take?
I look forward to seeing more work like this.
Mike Jones, Redding, CA
>I especially like the top edges that set off differing layers.
When do you find time to sleep?
charlie belden
>I asked this of Clay Foster - "When do you find time to sleep?!" I guess sometimes, in addition to all their other skills, some folks are really good at Time Management. Just getting turnings done can be time consuming. Add on just texturing and more time is eaten up. Doing carving - before texturing - again - time consuming. Add staining/ dyeing/ liming/ painting - the hour hand keeps moving. Then get into gold leafing . . .?
OK - so before the When Do You Find Time To Sleep - how do you turn you're imagination off enough to actually fall asleep - when you DO get to bed?
Turning, plus Post Lathe enhancements, sure creates a wide open space to explore. And there sure are a lot of explorers in this group.
I sort of like it.
Eddie Pacheco; San Jose, Ca.
>Not sure about the gold leaf. This side view really looks nice and only needs a foot tweaking. Make another one (easy for me to say) without the additional indent for the gold leaf.
A heck of a lot of work was invested in that piece, John, that's for sure.
Rob Wallace
Rob Wallace
>Hi John!
Nicely done form!
To my botanical eye, the "short vertical line" texturing on the sides of the vase reminds me of a fairly accurate representation of the vascular/vein structure of cholla cacti.....these vascular tissues are found throughout the stems of the plants. (For the techno-nerds like me, this is called an anastomosing vasculature.)
When the plants/stems die, the vasculature is all that is left. Fellow turners in Arizona, New Mexico, Southern California, Mexico, etc. will see these woody remains in any typical warm desert habitat in North America. Have you ever seen these plant parts before, or was this texturing motif developed independently (...or as they say, straight from the brain)?
Thanks for sharing this!
Rob Wallace
Re: That is pretty cool!
>Mike I used the router to remove most of the material. There were overlap lines that had to be carved away. I forgot that I bought a strip sander this summer when they were on sale but sometimes power cutting or sanding tools can get you in trouble. Sanding this area took the longest.
Carving the green side went fast because I used a power carver in my angle grinder. The texturing on the Cherry parts were created by using the dremel engraver with a rounded point. The texture under the gold leaf was the dremel with the pointed point.
I lost track of how much time it took because I was working on matching the finish on an antique clock at the same time. I would put some stain on and while it was drying I would sand or carve a little.
Re: I sort of like it.
>Eddie, I don't mind the gold leaf, just not where it's at. When I designed the piece in my head it seemed like a good idea. However if you understand how lights and darks work on a 2 dimensional photo, you know that lights come forward and darks go back. The gold wants to come forward and takes away from the recessed feeling of the area where I put it. In your hands it works better. The idea was to sort of peel away the layers to get at the gold. I don't think it worked as well as I would have liked, but it's the first time I've done this so you gotta start somewhere.
>Rob it actually came from an idea I had in my head and then expanded on it when I was eating cantelope. I liked the outside of the cantelope and wanted to somewhat mimic that texture.
The shape was simply designed to look somewhat fruit or gourd like.
Re: When do you find time to sleep?
>Charlie, I did most of the painting and gold leaf before or after breakfast each morning. In fact I left gold leaf pieces all over the table for my son to discover. I didn't have time to clean up before I left for work. I'm going to tell him I was listening to golden oldies.
Dick Hines
Dick Hines
>I like the carving but no so much the finish. That is just me , I like the natural wood to show.
Keith Tompkins
keith tompkins
>Hi John, I like this piece. I think the problem people are seeing is not so much the gold section, but how you resolved the way it meets the wood at the base. It ends abruptly, it may look better if it "faded" into the wood. I like the idea of layers; lots of possibilities there.
Michael Stafford
>I never think out of the box....I would not have guessed you used a router to remove that wood. I had in my mind's eye you sitting in your rocking chair tediously carving out all that wood...
Thanks for the explanation.
