Re: I need a new wheel for my grinder
Greg Haugen
>Joe,
Another option would be Sharpening Supplies; www.sharpeningsupplies.com
They carry "norton" wheels, white AO and both types of 3X at very reasonable prices, and usually the lowest.
As far as the dresser goes, that one will work and that's the cheapest option usually. The best dresser in my opinion is the one that Grumbine carries, www.wonderfulwood.com
As far as what grit? What did you have before? Did you like or not? If you liked it, why change it? I currently have a 60 and 120 wheels on mine. Depending on what I'm doing determines what wheel I'll use. If I'm roughing a bowl, I'll sharpen the gouge on the 60 grit or if I'm shaping a tool I'll use that one. If I'm "finishing" a bowl I'll sharpen that same gouge on the 120 along with all of my spindles tools. The grit debate is a personal perference. The whole issue of "burning" or overheating a tool on a 120 is hogwash! Too much pressure is being used, with proper technique this will provide an excellent edge.
If possible, try not to let price be the sole determining factor.
Hope that helps,
Greg H.
