Ground filler material
Philip Duffy
>When I see a beautiful piece of wood that has a crack in the body of the turning, I fill the gap/space/crack with a mix of epoxy and brass, or crushed stone. Then, when the mix is dry it kills my turning tools! Yes, I know there are alternatives but they just do not look so beautiful when all finished. So, in the turning process, I have found that the only tools that last more than a couple seconds are round nosed scrapers. I do not believe that carbide tipped tools would withstand the shock and probably chip out. \\ Does anyone have a better solution than scrapers? Phil
Re: Ground filler material
Thom Sayles
>I don't know if this response will help but it is what I do. I don't fill cracks with material and then turn the piece. Once I fill a crack with coffee, stone, or filings held in with superglue, I turn the bowl around, cut off the tenon, remove the bowl from the lathe, and then I sand not on the lathe but on the bench. No tools are made dull this way but you can go thru a bunch sandpaper. You also lose some roundness and smoothness of shape. I find that usually when a bowl cracks, distortion takes place so trying to turn it round again is hard. I have a big compressor and use autobody die grinders and sanders to help. An electric random orbital sander is used alot also.
Barbara Gill, Remlik VA
>Phil, I do not use stones but I do use brass. Is there a reason that you use epoxy? For small voids I use CA. For much larger if I fill I use epoxy (West System). It seems as if the epoxy is harder on the sharp tool than the CA.
Is there a difference in the hardness of epoxy? I think West System is supposed to be slightly flexible.
Re: Ground filler material *LINK*
>Try the Thompson tools. I regularly turn brass and aluminum with them. If they do that will certainly turn brass filings.
Or you can use alternative materials. The colored plastic chips sold to be used in Inlace are really nice looking. I like using them in the Inlace material but you can use them with epoxy or CA just as well. I buy them from Turtlefeathers.net
http://www.turtlefeathers.net/
Norm Smith
>Philip, Before I fill any voids with whatever I have the piece ready to sand. I fill the voids, sand them lever with heavy grits, start the lathe and than continue with the sanding of the piece with graduating grits. I do a lot of inlay with stone, etc and have found that this is the best process. Once you get used to doing it this way you will find that it is the easiest process.
Good luck,
Norm
I turn crushed turquoise with...
Allen Neighbors
>cutters purchased from use-enco.com in my Oland tool. I use the cutters that have 10% cobalt. No problems. High speed, light, shearing cuts. I don't have to sharpen them but a couple of times when taking down a patch of about 1", or so, length.
I have a couple of cutters that were my Dad's when he worked in the shipyards in San Francisco during WWII. They are not carbide, but are better than the 10% cobalt cutters. I have no idea what metal they are made from, but I only use them for Turquoise, and now they are getting a little short. :( I'm gonna hate it when they are gone.
Re: I turn crushed turquoise with... *LINK*
Steve Russell
>Hello,
I have been using 3M's diamond based abrasive disks. Here's my protocol:
Crushed Stone Sanding Protocol
Step 1- Course (250 Micron, 70�Grit Equivalent) Diamond Disks
These disks are a micron graded, nickel bonded diamonds bonded to a strong flexible backing that will work with standard Velcro faced sanding mandrels. The diamonds are arranged on the disk in an open dot type pattern, which allows the disk to cut very aggressively. They make short work of sanding the uneven crushed stone surface, so you can quickly move on to using your finer abrasives.
Step 2 - Fine (125, 74 and 45 Micron, 120, 220 and 320�Grit Equivalent) Diamond Disks
After the bulk of the rough stone surface has been sanded, I switch to these finer film backed diamond disks and sand the inlay with 125-micron (orange), 74-micron (teal) and 45-micron (beige) disks until the surface is flush to the turned surface. The 45-micron disks leave the surface at approximately 320-grit. These disks feature micron-graded diamonds that are resin bonded onto a 5-mil polyester film backing. They leave a uniform and consistent scratch pattern and can be used wet or dry.
These film-backed diamond abrasives are used to sand the stone inlay up to 320 grit.
These abrasives come three to a pack and are available in 2" or 3" disks. Costs range from $6.00 per pack for the 2" size, to $7.00 per pack for the 3" size disks. Disks are very durable and long lasting and are easily cleaned with water, or a soft bristle brush.
Step 3 � Traditional Abrasives for Finish Sanding
Once the inlay is sanded to 320 grit, traditional abrasives can be used to complete the sanding. You can use traditional abrasives like heat-treated Aluminum Oxide to complete the sanding of the crushed stone inlay and the project from 320-grit to the desired level. Diamond abrasives take most of the hard work out of sanding crushed stone inlays.
Once the inlay is flush to the surface of the wood, it's easy to continue finish sanding with your regular abrasives (as long as the abrasives are harder than your stone inlay). In addition to Aluminum Oxide abrasives, I occasionally use Silicon Carbide, or some of the newer ceramic abrasives to finish sand, depending on the specific project.
Here is a link to a recent article I wrote that gives some more information and pictures of the abrasives, since uploading photos is a challenge at times:
My Crushed Stone Abrasive Protocol
Steve Russell
>Forgot to mention...
Although the 2" and 3" 3M diamond abrasives can be used dry, they will last longer if you keep them slightly wet, or damp during use. A small pump spray bottle of water is a great way to spritz water onto the disk occasionally when sanding. Spraying the disk also helps to cool the disk and remove some of the dust residue. 2" pads cost $18.00 each, 3" pads cost $38.00 each. Pads are very durable and easily cleaned with a shot of compressed air, or water and a small soft bristle brush.
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
Dick Hines
Dick Hines
>Like Steve I don't fill the cracks until I have finished turning the piece. Then I will fill the cracks. Sand paper is cheaper than a bowl gouge. Or scraper.
Thanks!..
Philip Duffy
>So many great answers! I knew I could count on the wonderful world of woodturners! Philip
