1st carved piece, "Leaves"
keith zimmerman, Normal IL
>Here is my first carved piece. I started this at a hands-on workshop our club had with Trent Bosch this past October. I was intrigued by his technique and decided to run with it and see what happened.
The wood is cherry, which was green and very wet. It was hollowed with my 1/2" Kelton hollowers mounted in my Don Pencil Scorpion armbrace. I started carving out the basic shape of the leaves and stems at the workshop, but quit so I could do some other work. I wrapped it in a plastic bag filled with the wet shavings from the hollowing to get it home. Circumstances did not allow me to get back to it for several weeks and, by that time, it had partially dried to an oval shape, which surprised me because it is endgrain.
Anyway, the carving on the leaves was done with my Dremel using flame shaped silver Kutzall burr, followed by lots of sanding to smooth them out. The background was textured using a HHS ball in my Dremel. The finish is black leather dye followed by several coats of Krylon matte low odor varnish. the piece is about 6" tall to the top of the highest leaf.
All in all, I am quite pleased with this piece and will probably continue to add carving to my design palette.
Thanks for looking.
keithz
