>i just purchased a new norton white grinding wheel to accomodate my 6" grinder to which the previuous wheels, a pair of "ryobi specials" I like to call them, came with. The old wheels ran true enough to produce a sound edge. Although Once mounted, this white wheel is vibrating like crazy. Any solutions from the panel? :) thanks clay
>Did you try truing the wheels? I understand grinder makers sometimes true the wheels to the grinder which makes up for sloppy runout tolerances on the grinder itself.
I recently replaced wheels. I tightened a wheel and checked for vibration. Then loosened the nut, turned the wheel about 1/8 turn, tightened, and checked again. I found a spot where it ran with less vibration, trued the wheel. Might also try reversing the wheel.
I ended up going to the ultimate solution: the Oneway wheel balancer. About $60-70 I think, it lets you static balance each wheel and the result is SMOOTH. You have to get the right arbor size for your grinder and the wheels themselves need to have a 1" hole, if I remember. I don't know if it will work with a 6" grinder.
>I would try what John said. Loosen the nut and turn the wheel. It may take a few times. I usually rotate it fairly slow and touch the wheel gently with a pencil. This locates the high point. Sometimes you can rotate the wheel so this high point is 180 out and get rid of the problem.
In a worse case scenario I have used brass shims to help true up the wheel. When you get it as close as possible use a diamond truing jig to true it up completely. I've had good luck with a T shaped diamond tool from Woodcraft. I put in on a solid tool rest and slide it sideways back and forth.
I also have a single point truing jig that I built that works OK, not great but OK. Don Geiger has the best truing jig if you have a oneway system or his system.
>This happens every time I buy new grinding wheels and truing them ususally corrects the problem. Has anybody tried the wheel balancing systems? Are they worth the investment?
PS - I noticed the guy crosscutting logs on his bandsaw freehand had them on his sharpening podcast. Maybe that answers my question. :>)
>Brain Simmons had the balancer on the 6" slow speed General grinder and it ran so smooth you just about did not know it was running by sound. You need to have enough shaft length on a 6" as some you cannot hardly mount 1" wide wheels if they came with 3/4". I like the wider wheels.
I have noted before I had trouble with 6" Norton white wheel and used my old step plastic bushings as the new must have been off center.
>I have the Oneway system and it is fine. I used them on the Norton 3x blue wheels and didn't need weights. IMHO, besides balancing as JKJ did, check the holes. Almost all plastic inserts are the cause of vibration.
