>Powermatic does not make a tailstock riser block for the 3520b. I'd like to be able to turn longer spindles with the bed extension in it's lower position so I'm not switching the bed up and down. I'd also use the riser for coring blanks larger than 20" diam. with the oneway easycore. Has anyone attempted to make one with any success?
>I've thought about it. I haven't actually measured all the distances but the extension is only 18" I believe. The tailstock with a live center is probably 10 or 11" so you might be able to put a blank on there that's 6" deep if you move the wood really close to the bed of the lathe.
You can easily build one from MDF. I did that for another lathe and it worked fine. A better option would be to weld one up out of heavy gauge sheet steel and then have the top and bottom surfaces milled parallel. You would have to make an extension for the locking mechanism. I haven't looked at it close enough to tell you how hard that would be.
>Since the bed extension is so short the tool rest banjo would have to be under the piece so you could subtract another 3" from the overall swing of the lower bed.
>Thanks John, I'll try it out with mdf and see how it holds up. Maybe use a piece of thick steel for the tailstock to lock on to rather than exending down to the 18" bed extension. I'll try and think this one through.
