Task Light Revistied
Gunslinger
>Task Light � Out-of-the-way (with alternatives)
This is a light for my lathe. It is two 19� gooseneck sections but Sam Ash also has
6� and 11�. It will support the weight of the light at 19�+ but not at the full 38� (hence the Velcro strap which itself slides on a section of PVC pipe.)
I attached a 100 watt halogen spotlight from Home Depot. The light fixture is "Taymac LH510B". (It is far enough away that the heat of a halogen is not a factor.)
I mounted mine to the wall to provide light from the headstock, tailstock, or outboard.
You can also mount it to a magnet to attach directly to your lathe. I didn�t want to have to move the light base or have it in the way�all I have to do is swivel it to a new position.
Total cost should be about $30 for the goosenecks and light fixture.
Below is the link to the web site where I purchased the goosenecks and mount.
http://tinyurl.com/5srkrw
If this link does not work for you, go to www.samash.com
At the site go to �accessories� then �stands� then �mic mounts and accessories�
The item numbers for two of the extensions are 6581 and 6576. The gooseneck mount is TM088. Two 19� extensions and the mount is about $20.00. The ends of the extensions are already fitted to mate with each other or the mount.
It was no problem running lamp cord through the extensions. You can then mount your light and secure to the wall, ceiling, or a movable magnet.
The Taymac light has standard fittings for outdoor lighting. I took a dremel and slightly enlarged the inside of the Taymac fitting. The lampholder is aluminum and the gooseneck is steel. I then force threaded (lightly) the gooseneck into the lampholder and added a touch of CA glue. This leaves the swivel on the lampholder itself usable.
(An alternative for mating the two items�take a 1� square piece of wood and drill halfway for the light fitting and then drill for the smaller gooseneck fitting the rest of the way through. With a snug fit and a touch of CA glue it should last forever)
The Taymac with its small size (3W X 4L), light weight, and 100 watts works excellent for me. No problem seeing into the deepest bowl or vessel with the light four feet away. When used at an acute angle to the work, it also highlights the smallest scratches or defects on the turnings.
Mounting Alternative. If you have room around your lathe, make an adjustable stand for the light. The fixture can be mounted on a gooseneck (as above) or mounted to a boom from the stand. With the height adjustment on the stand and the swivel adjustment on the light fixture you would not need a gooseneck. The stand shown in the pic is my task fan, which adjust up and down or swivels around. With a stand you can also use it with any other machines in your shop. Sorry, no pic..could only post one.
