Can the Oneway Spindle Steady...
Cyril Griesbach
>also be used as a bowl steady and why not?
Re: Can the Oneway Spindle Steady...
Bill Howatt
>It's got a third wheel and envelopes the spindle and the wheels are flat (1" wide) which would likely be somewhat more problematic on a curved outer surface. You might use it on a small diameter long length bowl within its capacity though. It is possible to buy just the wheeled portion without the base and post if you already have it.
billh
>I have a Oneway Spindle Steady. I would not want to use it as a bowl steady.
As mentioned three flat 1" wide x 2 1/4" diameter wheels.
The maximum bowl diameter that you could work with would be on the order of 3". Two of the wheels are on the same "arm" - which really limits your bowl diameter. It works great as a spindle steady. I use it for skinny stiles and I have used it for turned chair spindles.
Now if you had a relatively long neck on a hollow form, you might be able to use it....
>cyril I have wondered the same thing. A bowls steady just touching the outside where your cutting would not be that much different than what I do with my fingers on the outside to reduce vibration. I only have a homemade 3 wheel steady or I would go home and try it.
I'm Going to Change My Tune a Bit
Bill Howatt
>Upon further examination, you probably could bring up the lower wheel and one of the uppers (I think I have that the right way around) and contact the bowl similarly to their bowl steady. The wide wheels also might be easily exchanged for a couple of in-line skate wheels too.
Bill
Re: I do use the Oneway bowl steady.....
Jamie D
>...on my Stubby, and haven't tried using the spindle steady in its place since I don't own one. If you haven't already bought the spindle steady, I would suggest that the bowl steady can also be used as a satisfactory spindle steady, and it's less expensive.
Bill Howatt
>The bowl steady wheels are rather large for a thin spindles and it really only provides support on the side opposite the cutting force when doing the inside of the bowl. The spindle steady provides support on the back side of the spindle as well and the smaller dia wheels accommodate smaller spindles.
Bill
Cyril Griesbach
>Thanks to all for the responses. Bill Howett pointed out the wheel difference that I failed to notice. Our club is putting in a CAUSA order so I think I'll go with the bowl steady since spindles aren't my game.
Re:Bill- the bowl steady works much .....
Jamie D
>.....better if you run it behind the area you're cutting, not on the opposite side. It counteracts the pressure from the cutting tip and stabilizes the wood in the area actually being cut away.
Re: I'm Going to Change My Tune a Bit
JohnKyler
>Although I have not tried it yet.
I do know that the wheels can be exchanged for inline skate wheels, as I have done that so that there was less friction /contact for a spindle steady.
John
Bill Howatt
>My terminology meant opposite as in "the other side of the bowl wall" not on the far side of the bowl.
Bill
