Photo Tutorial *LINK*
Re: Photo Tutorial *LINK*
Re: Photo Tutorial
HeatherA in AK
>Thanks Neal, that is just what I need.
Heather
Bill Blasic
Re: Photo Tutorial
Bill Blasic
>Nicely done Neal!
Re: Photo Tutorial
bowlman
>Do you use GimpShop to get all the controls into a Photoshop-like view? I noticed GimpShop is based on Gimp version 2.2. Is Gimp SHop compatible with the current Gimp version 2.6.4?
Re: Photo Tutorial
Bill Noce Northeast Ohio
>Great job Neal, the best tutorial I have read it really helped, thanks
Excellent job Neal
Thanks Neal !
Don Orr
>Very helpful. Hopefully I can take better photos and actually post once in a while. Between you, John L. and Jamie I should be able to get the hang of this.
Re: Photo Tutorial
charlie belden
>Another missing link!
In an earlier thread, Jamie D. noted that photos are the communication method for presenting our turnings - and most of us are photo illiterate or are barely literate. The information you put together - in one place - which focuses specifically on photographing turnings fills a need nicely.
Thanks for the time and effort you obviously put into this very useful and easily applied info. Being a curious sort, I particularly like the ability to bore down into details - if I choose to - without having to slog through them if I don't want to.
Much appreciated.
Re: Photo Tutorial
Allen Neighbors
>Well done, Thank you.
Re: Your Photo Tutorial is an excellent ....
Jamie D
>...production for improving the visual language among turners. I hope many will consider improving their photo skills by using your information, and we will all benefit from better imaging as our means of communication.
Neal Addy
>Thanks for all the kind words! This is just my way of giving back to the woodturning community for all the great help and advice I've received over the years.
I'm also gratified that my tutorial passed the Jamie D and John L test! LOL!
Thanks again.
Re: Photo Tutorial
Texian
>Good job Neal. And/but the yellow print is almost impossible to read on my monitor. Maybe need to turn up my contrast or something. Still was able to navigate, knowing that the blank space with a hint of yellow probably said "next". And how's the next chapter (f-stop, depth of field, shooting in RAW) coming along? Meanwhile there shore 'nuff is a little flower on that dial. Time to get out the book again.
Lighting question
Alex Yeilding
>Excellent tutorial. Bookmarked to read before I start another project that I want to photo-document. Thanks.
A question about lighting/color page. The four photos are described as images with white-balance set to daylight, taken under different conditions. I'm an old film guy, so this might be different in digital, but those look like photos taken in daylight, with the white balance set to the different settings. With film at least, if you use daylight film (~5500K) and shoot in incandescent (~3200K), your photo would have a yellow cast. The blue cast you illustrate would occur if you shot with incandescent film in daylight or with an electronic flash. I assumed that white balance was analogous to film temperature.
Re: Lighting question
Neal Addy
>Alex, good eye and good catch! You are correct.
When I wrote that section I had originally shot the example photos under the different lighting conditions but later switched to a using simulated WB setting (all shot under daylight) in the final edit. I neglected to change the wording. I'll correct that.
Thanks!
