Portable tool & light stand
George in Minnesota
>My workshop shares the space in our 2 car garage with one vehicle, refrigerator, snow blower, and other non wood related stuff. I am very tight for space because I still have kept my equipment for flat work in case I actually retire one of these years. I have been "noodling" in the back of my brain about building a stand that could sit across the lathe and contain:
- dust hood
- lighting (already bought 2 Moffatt lights)
- vertical tray for large tools
- drawers
- pancake air compressor.
I was wondering if anyone had ever thought about such a set up or am I trying to throw too much together at one.
Attached is a crude mock-up of what I am trying to explain, I would put on some type of A-frame structure with wheels (similar to Norm's clamp cart if you watch the New Yankee Workshop.)
Comments & suggestions please..
Thanks
George
Re: Portable tool & light stand
Richard Allen
Richard Allen
>Where is the sharpening system?
George in Minnesota------WebKitFormBoundary4tOvPnM
>It is in a separate stand to my left.
>I like your thoughts and ideas - except for the lighting part. I prefer for the lighting to be above the work. A potential problem is the alignment of your tubes for the tools. They may end up with lots of chips and dust in them. You might consider a vertical orientation on either side (or both sides) of the cabinet.
Bob Macgregor
>If you need more room...it sounds to me like you still have one too many vehicles in the workshop.
Gunslinger
>Probably not what you have in mind but�it may give you some ideas.
Nothing is to scale on the attached.
IF you do not have a shelf under the lathe for added weight, you could make a cart to slide under holding the dust collector and other items. When used, roll it out and connect your duct with quick connect.
Instead of doors/drawers you could have shelves with a full canvas cover to keep chips out. That would be my election.
Top cabinet would also be rolled out when used. It could come down almost to the headstock leaving room between them (8�?) to leave a turning on the lathe if you want to.
The left doors would not be as tall (not shown), leaving room to mount the dust hood to the wall.
The right door(s) could hold tools both inside and out on magnetic strips, just recess the drawers or shelves inside about three inches. You can also mount racks on the outside ends to provide more tool storage (as previously suggested).
I agree with JL that the lighting should be above for most turning. Make the top cabinet depth so that six inches remains behind it while the front frame comes out to the front legs. Mount the lights to the wall about 16� above the headstock level and at each end of the lathe. You can then move them up or down as you desire with the gooseneck and swing them again the wall to store the top cabinet when finished. I find it very helpful for finish work to bring the light down to a couple of inches above the work level and have the light shine parallel to the work rather as it shows defects much easier. (You can leave the other light shining from above.)
Mike
Re: Portable tool & light stand------WebKitFormBou
>If I were not living in Minnesota, I would whole heartedly agree. The vehicle stays outside once the snow melts and low temperatures stay consistently above 20. SWMBO has conditions for my tool purchases 8-).
------WebKitFormBoundaryoMh+F5LvTLwPg6wu
>Thanks for the additional ideas; I cannot store underneath the lathe due to the model (Oneway 1236SD). I like the ideas above it however.
Thanks
George
Gunslinger
>Hi George,
Another idea�.
Make a track on the wall with 1x4�s overlapped. Reverse lap for the back of the hood.
You can then position the hood anywhere along the lathe. When not in use slip the hood off of the track and lay on the lathe bed. You can then make the upper cabinet full length and have no cutout for the hood. Also, if you do leave the six inches behind the cabinet for the lights, use the extra space for magnetic strips for tool storage. This assumes it will be an easy reach over you lathe to get to them.
Mike
George in Minnesota
>Good idea as well, thanks. Now to the drawing board.
George
