THE WOODRAT IS BACK!
last weeks work
last weeks work
last weeks work
>This is the work I got done last week. The bowls are cherry as well as the carved vessel. The metal piece is a tool I made for the metal lathe to hold die's to cut thread square to the axis. The carved vessel isn't actually complete. I'm not happy with the rub on gold so I'm going to gold leaf it instead. Then I'll take a decent photo of that piece.
I also spent the last few days working on a little pantry type closet under the stair well. That is a pain. nothing is square under there so every board has to be measured carefully and odd angles cut.
Re: last weeks work
Re: last weeks work
MFoster
>That's a lot of nice work for a week. Will be interesting to see the final result on the carved vessel. Your amount of energy to work a full week and then produce so much in the shop is an inspiration.
I did some tool making over the weekend as well (converted my old laser pointer into something more like the Jamieson system) Seems I'm always tweaking something to make things easier or work better.
I haven't yet tried my hand at leafing, but it has always intrigued me and is on my short list of things to do.
Re: last weeks work
Go for it-leafing isn't hard
>True gold leafing is a science and takes lots of practice. What most turners do is not the same thing but the procedures are similar just a lot less finiky. Gold leaf is expensive and very delicate but it can be burnished to a high sheen and follows the most delicate details.
What most of us use is a flake gold leaf which looks pretty nice but is much thicker and less fragile so handling it is quite easy. We also use copper leaf, and silver leaf.
Quite simply you paint an undercoating that might show if the wood moves and the gold cracks. Usually this is red but it could be anything you want. Then you put a sizing on. This is simply a flue that slowly becomes tacky. When it's tacky enough to just be a little sticky when you touch it with the back of your knuckle, you can put the leaf down. They sell expensive brushes to do this and you probably need one for pure gold but for the leaf that I use your fingers work well if your careful. If you have cracks or spaces simple put some more size down and put more leaf on top.
With all the fake gold leafs you will have to put a finish on top. Real gold won't tarnish so it doesn't need a finish.
That's it in a nutshell. Give it a try on something simple or something that doesn't count. You can find a lot of good information on the net if you want to go all out and do it correctly.
