How to make a small round nose scraper?
Joe in a Cleveland Suburb
>Hi,
In FWW #196, Christian Becksvoort shows using a small round nose scraper while making Shaker style knobs. I was at WoodCraft yesterday and there aren't any "small" ones. They were 1" or better. I'm not sure what size "small" is but in the article it appears pretty small.
Seems like this would be an easy tool to make. Can anybody tell me ways to make one? From what material? How to put an edge on it and so on?
I am a turning lurker and noob, so sorry if this is noob'ish question! :D
Thanks.
Joe
P.S.
For any of you Cleveland area folks, WoodCraft in Cleveland plans on moving further away from Cleveland I am told. Rumor is out to Macedonia area. Way too far for me... It's already border-line too far. Sad, because we recently lost a good Rockler too.
Re: How to make a small round nose scraper?
>Joe,
I made a couple of small round-nosed scrapers recently. I simply took a grinder to a some pieces of steel, in this case a 3/8" round hardened tool blank from Thompson tools and an extra detail gouge. I had never used a scraper that was round instead of flat, but after trying it I love it since I can tilt it easier. Thompson also offers flat scraper blanks in a 1/2" size, perfect for small scrapers - I ground one flat on the end and on the edge recently for the inside of small flat-sided boxes. You can basically use any piece of any kind of steel, but those made from HSS or better will hold an edge longer.
You can also "repurpose" a tool you no longer need. For example, get a narrow flat scraper or a small skew chisel and grind the end to the profile and angle you want. Set the flat toolrest on the grinder to perhaps 70-80 deg and grind until the nose is rounded. I like to hone the top then raise a "burr" with a hardened rod or the shaft of a small gouge - simply hold the tool firmly in one hand, hold the rod nearly even but at a small angle to the bevel you just ground, and press hard into the edge while sliding the rod around the scraper profile. You can feel the raised edge with your finger. It doesn't take much - be careful since too much raised edge can make it very aggressive.
For the little scrapers I made from round rods, I also had to grind the top flat. I made this flat at an angle of about 5-10 degrees. This resulted in a "negative rake" scraper, all the rage these days. I ground the sides flat as well to allow it to get into tight places. I am a bit surprised and quite pleased at how well these scrapers work on both end and side grain. (I use these straight off the grinder without raising the edge as mentioned above.) Since I use these for small things close to the toolrest, I don't put handles on them which may be needed for significant overhang, but for that I'd probably wouldn't want a round rod anyway but use a flat scraper I could hold tight to the tool rest.
If you want, I can try to take a photo.
Greg Haugen
>Joe,
In my opinion "small" would be no bigger than 3/8" and probably more to the 1/4" size. For a 1/4" scraper, I'd look into MSD Direct, or ENCO, for a 1/4" "Blank" of HSS. These will probably be square stock, which will be good to dampen vibration. I have one 1/4" scraper that was made by Bob Rosand. The steel even has the "ENCO" label on it. I think their blanks, around 8" long or so, are a couple of bucks. They may not be the higher end HSS steel we're used to but for a small scraper, they work great.
I also make some two piece tops. Tops have to be very precise. After I drill the hole, it's not always perfectly centered and it can throw off the top. I made a round nose scraper, under 1/8" diameter, out of a chainsaw file to "true" the little hole by simply flattening the one side, for the top, and then flipping it over to grind the bevel. IF you'd like one that is round stock to "shear" a little easier, screw drivers or round files would work.
Hope that helps.
Greg H.
Re: For occasional use a screwdriver.....
Jamie D
>...can be "sacrificed" to make a scraper as well as excellent hollowing tools for small objects like ornaments. And every shop has a few extra screwdrivers that can be recycled to make more useful tools!
>I agree with Jamie. I have 3 that I use all the time. You can get them at the flea mkt's for 50 cents to a dollar or even cheaper if they are rusty.
I use old planer blades and either use the whole blade and just glue it between some wood for a handle, or I cut off 1 or 2" pieces and regrind those and screw them to a round bar. I cut slots in the blades with an angle grinder and cutoff blade to mount them to the steel shaft.
By old turning tools from the flea markets and regrind them to your needs.
>Thanks for the replies. I guess I hadn't considered grinding down an old screwdriver. There are a few of those lying around.
I suppose I would just grind it down to look similar to the scraper I already have, then try to put a small bur on it?
I would have guessed a screwdriver's metal would be too soft, but I'll give it a shot.
Thank you.
Joe
>Screw drivers vary a lot in hardness. Some actually have hardened tips inserted. I've found the old ones have better metal for our purposes.
I prefer turning my shaker pegs with a spindle gouge rather than scraping. Rude Osolnik made chess sets and he custom ground planer blades to the shape. Rude tended to do things right so if it works for him it should work for you and me.
Last night I looked through my drawer of screwdrivers and what not. I found an old worn out spade drill bit. Ground it down to look a little like a small Popsicle stick on one end. Worked like a champ.
Thanks.
Joe
my favorite mini skew is a spade bit-reshaped
