Took up the hollow form challenge
MFoster
>I think John Lucas posted the thread regarding how long it takes one to turn a hollow form. I had a ball park guess, but decided to see what it would take me. This form took me about 3 hours (5 if you count the piece of firewood described below). I did not sand it to completion, as I intend on carving and texturing it after it dries, maybe ala John Jordan. I spent time with it to get the form I wanted and work around some flaws in the sapwood that I did not want to keep. It is finished to a wall thickness of about 5/16" to allow for carving. I don't know where I could shave much time off as I tend to fuss with form. I guess I'm just slow.
The picture shows that I coated the end grain with wax, which is why I lifted it off the background paper. It was actually liberally applied. I did this to hopefully keep it from cracking. The next pic shows my first attempt. While almost finished with the hollowing, I heard a couple little pop's. I knew what had happened even before it stopped spinning. I did some quick sanding on the outside after getting the form, but nothing that would have heated up the wood. I think this happened because the wood was felled in the summer when it was really wet and sealed. It was sitting in the basement of the barn and frozen due to the temp. I think the sudden thawing of the wood in the shop and the low humidity were the factors working against me. After turning the outside shape on the second piece, I coated the endgrain with anchorseal to prevent a recurrence. Am I the only one that experiences this. I find this happens to me more than I would like, but don't know what I can do to minimize it. Anyone else have the problem?
The piece is split leaf maple and about 6"d 9"h.
