Re: pen turning problem
Scott Greaves in Blackfoot Idaho
>Hi Karl,
It is likely that you just need to tighten the nut on the mandrel a touch. As mentioned above, tightening it too much can bow the mandrel, causing an out-of-round pen. One other thing you can try is to turn the speed up on the lathe. So try this: Snug the nut on the mandrel, turn the speed up, and take nice light cuts with a sharp tool!
It's very unlikely that the glue bond broke, and the brass tubes are spinning inside the blank. Unlikely, but not impossible. If you try to take the blanks off the mandrel and the brass tube stays behind, then you know this has happened. But I certainly wouldn't begin with the assumption that the glue bond broke.
Let us know how this works out for you!
Scott.
