Inspirations From Outside The Box
charlie belden
>So I�m in bed flipping through an issue of �american craft� magazine before heading off to rest in the arms of Morpheus. Big mistake. Just about every pair of pages had at least one photo of a piece, or something in a photo that got my brain churning - �How could THAT be done - on a lathe?� or �That COULD be done on a lathe!� or �I wonder how he/she got that surface texture?� or �Hey, if you pierce at an angle rather than square to the surface - and your walls are thick enough - what you see - or don�t see - would change significantly as you move the piece, or move around it!�
Fortunately, I could sleep in the next day since I couldn�t fall asleep for several hours after opening the magazine. Since I own the magazine, I could dog ear pages that had something interesting to follow up on - or not. The magazine is now noticably thicker at the top corner than at the botoom due to all the dog earing. I haven�t yet been able to bring myself to cutting out the interesting stuff - and pasting it in an Idea Binder. But I suspect that will come - in time.
Among other things, I�m a Woodworking Magazine Phreak - furniture, turning, carving. I pick up one or two of each a month and find a gem or two in each one - some pursued and some just filed away for some future use - a concept here, a technique there, a How The Hell Was That Done?, A better or easier way to . . .
Maybe it�s because I�ve dabbled at turning all sorts of things using all sorts of methods - but only a few lathe chisels and gouges - and chattered, pierced, pyrographed and played with all sorts of texturing - that I can look at something and come up with a way to do it, at least in part, on the lathe, though it may require a tool or an accessory purchase ( did I mention that I�m a Tool Phreak?). The end results may not be refined to perfection - but that�s usually just patience and grunt work.
I doubt that this Look Outside The Box (look for turning inspiration in sources other than turning magazines, books and websites) thing would have happened earlier on in this turning journey. Just getting over the You Want Me To Take This Sharp Piece of Steel And Poke It Into THAT Spinning Chunk Of Wood?!!!! was a challenge. And you must admit, it�s kind of counter intuitive that increasing the rpms actually makes turning easier - and argueably safer. Then there was the Significance Of A Sharp Edge thing - and all the sharpening skills lathe tools require (flat and straight is so much easier to deal with than round and curved).
But now I�m at least adequate with the lathe chisels and gouges I use, I�ve figured out how to sharpen them, a catch doesn�t scare the hell out of me anymore, I�m comfortable with mid range rpms (I doubt I�ll ever get into the high 2K or low 3K range), I�ve turned a bunch of different kinds of wood and have a feel for which lends itself to what and which DON�T - I can find inspirations Outside The Box and probably come out with a piece that I like which uses that inspiration.
Got any Outside The Box inspirations Sources you�d care to share?
