Question on turning post in two pieces??
>My son and a friend are trying to make a coat rack out of aromatic cedar. My lath has about 40 inches between centers, so they turned it in two pieces about 36" each. They drilled a hole in one end of each piece and then put a dowel in the hole and turned the two sections, then used the dowel to join the sections. They did a nice job on the pieces, but there is a slight dog leg in the post. Probably between a quarter and half inch if you lay it on a flat surface and roll it over. Many people would not see it, but you know how that critical turner's eye is. Any suggestions on how this happened and what to do about it?
Re: Question on turning post in two pieces??
Richard Allen
Richard Allen
>This is always a problem with two piece work. Making a tennon on one piece can reduce by half the runout. If you put a tennon on both pieces then u\you can further reduce the runout. Make those tennons about 5/8 to 2/3 of the diameter of the primary piece. The longer those tenons are the less chance there is for joint runout. Drill a piece through the piecc the for the tennons to slide into. Mount this drilled through piece on a mandril you have between centers to turn to the desired diameter and to make sure the ends are square to the piece. Yea I know this makes a three piece post not a 2 piece post.
>You didn't mention if you mounted the piece between the centers using the holes as your center. Normally when turning 2 piece spindles I turn a tenon on one piece and a hole on the other. The one with the hole is mounted on a cone shaped live center so the hole will be perfectly aligned. You could use this method with 2 holes and a dowel.
Another problem would be if the holes were not perfectly aligned with the shaft. then you would get sort of a boomerang look.
Bill Grumbine - Kutztown PA
>Barry, a friend of mine who is a wizard when it comes to repairing furniture does it this way. Take the two pieces and drill the hole as you have done. Then, take an undersized dowel, so that you will have enough slop (i.e. movement) to align the pieces correctly. Then, fill the holes with epoxy, insert the dowel, clamp it all up and wait for it to dry. This repair is done on a regular basis for chair parts and works great.
Bill
>Thanks Bill, That was pretty much what we figured. He wanted to leave it so that he could take the thing apart, So we might just glue one end.
I did not help him with the setup, so I am not sure he got the dowel dead on. I am curious why it came out crooked so we can do it better next time. Woudln't take much though.
>Bill Exactly what I do when repairing antiques because nothing is usually round anymore, except for the new piece I turned. To give it more bite I often use a short piece of threaded rod.
