Fruit Cherry vessel
Fruit Cherry vessel
Fruit Cherry vessel
Curt Fuller
>This is from a piece of fruit cherry that a friend gave me. It has some awesome color and figure. The knots are filled with a coffee-CA mix. Unfortunately the lid cracked, being endgrain with the pith in the center, so I filled it with black dyed epoxy. The finial is rosewood. 11" tall, 4.5" wide, with Deft semigloss lacquer.
Re: Fruit Cherry vessel
Curt Fuller
>This is what the wood looked like before turning.
Ray Binnicker
>Curt,
Very NICE !!! I've looked at for a long time and I can't see a thing I would (If I COULD (:-) )have done differently.
Questions:
What did you use to dye the glue black?
How dry was the wood when you started?
Again, Great job !!!
Ray Binnicker
nick
>I like this piece a lot, particularly the star-shaped checks in the knots. But I wonder why you used a blank with pith in it to begin with. Another small suggestion- the lid might look a little better if it filled up more of the recess it's set in- I mean it's set too deep for my taste. Still, overall I like it.
Curt Fuller
>Thanks Ray!
The epoxy is dyed with the alcohol based dye from craftsupplies. Just a couple drops in a little 5 minute epoxy. The wood was pretty dry, I had to cut a couple inches from each end to get past the checking. But not quite dry enough to keep the thin lid from cracking. I probably should have soaked the lid good with CA and it might not have cracked.
Curt Fuller
>Thanks Nick. I turn quite a few pieces from wood that includes the pith. There's a lot of character with the knots going out in all directions. As for the lid, I guess that's just my style. Wood always moves a little and a lid that doesn't line up exactly with any other lines on the piece doesn't seem to show the movement as much.
