New Delte Midi lathe
Bill Noce Northeast Ohio
>Looking for info on the new Delta Midi Lathe coming out in Feb. 2009.
I read on one of the forums but cann't remember which one. A senior moment...lol
New Delta Midi lathe was mentioned ...
Ed Moore in SW Virginia
>in the thread I started about the Jet JWL-1220VS lathe. John Lucas and others were involved.
I ordered the 1220VS via Toolnut and expect it to arrive late this next week or the following week. Another toy, goodie, goodie, ... [grin]
Now to sell the 1014 ...
Ed
Re: New Delte Midi lathe
>It was here that I posted the info. You really couldn't read it reproduced that small. I don't know what I've done with the brochure that I had. I thought I scanned it but can't find it on here and can't find the brochure. Talk about senior moments. I'll keep on looking. Maybe I can answer your questions from memory (what little I have left)
Link to John's original post *LINK*
Mike Brazeau
Re: Link to John's original post
>Thanks Mike that the one.
keith zimmerman, Normal IL
>I still think this new lathe would be worth looking into. I like the idea of it only having a 16 1/2" bed matched with the 12 1/2" swing.
Hopefully, it will be a good piece of equipment at a reasonable price.
keithz
New Delta Midi Lathe
Derek Dix
>I am fortunate to have this new lathe in my shop. I haven't put it together yet but I did take it to my club meeting tonight and got a lot of good feedback. Some of the highlights that I can tell you about the one that I have:
- 1 HP motor
- 120 Volts single phase 8 amps
- Reversable
- 250 to 4000 RPM (3 pulleys)
- 12.5" diamater max.
- the bed extension is machined on the end so you could add a second (or third) extension on.
Another great feature is that it has a 24 point indexer built in.
I don't know the price or when it is due to come out but anyone that is considering purchasing a new Small lathe in the near future I highly recommend waiting and checking this product out. I hope to get it put together and start test driving it in the next couple of days.
So far my opinion of this lathe is that Delta got it bang on!
You have to review this new lathe
>I, for one, am extremely interested in your thoughts about this new lathe. I am in the market and am really excited about what I have read so far.
keithz
Ditto- I have a jet that I was going to convert
>to something like that but If I can buy it I would save a whole lot of time. I want to know the little things. How easy does the index work. How well the tailstock and tool rests lock in place. How clean are the castings, are the switches located logically and hopefully they are durable.
I know these lathes aren't the same as the big Powermatic but you when you use them to demo you want everything as close as possible to the big guys
Re: Ditto- I have a jet that I was going to conver
Mike Brazeau
>I am going to jump in as I was able to have a pretty good look at it on Thursday night. John - the index pin looked like it was about 1/4" in diameter and was spring loaded so that when not in use, you pull out and rotate it 90 degrees and detents for a small cross pin engage in grooves to hold it. We speculated that it could serve as spindle lock as well. Numerical Settings were printed on a wheel in fairly large numbers and easily read. The tailstock still has a circular disk gripping under the ways and that would probably be the first update I would make if purchasing. A small rectangular block has much better gripping power to stop sliding. Didn't have a good look at banjo but my recollection was that it was similar in design but a bit bigger than the one on my Delta midi. Did have a large tool rest. Overall finish was excelllent on the lathe. Not usual Delta gray, but a hammertone finish. The bed extension grinding was slightly rougher, but very acceptable. Very robust design with a set of legs that Derek had not installed for our looksee. Assume they will be optional. Two of us lifted easily out of the box and for you young guys, probably not a bad lift. I would not be moving it around a lot alone if I had it. Haven't seen a Jet 1220 for comparison as we can't get them in Canada, but the bed width dimesions are more like a full size Delta. Belts looked 1/2" in width and they have a quick release on tension, much like concept of the Delta bandsaw tension release on a small scale, so changing positions is easy. The VFD is mounted on the back of the headstock flush to the top with a rotary speed control pointing out to the left. The On-Off switch raises on the top and for an emergency is available to slap down. There is a slide switch for Fwd/Rvs. There were some comments about positioning of the speed control but I think it is all a matter of getting used to it. Virtually every other lathe has it on the front, but on this one you have to swing the cover down to change belt positions and I would much rather have the accesss door on the front than on the back like Jet do. Very impressive lathe with good industrial design. Starting speed is 250 which would be nice if lower but must be a factor of 115 volt input? Haven't run it and Derek will be soon so he can give us some feedback on power etc. but with 1 HP should not be a problem. Be a great little lathe for that last place before the nursing home if I don't end up with a 1236SD!
I have the non-VS model Longish
Angelo Schembari
>Our Turning club was given the new "midi" to demo. We did not get a VS model.
All in all this is a VERY well made machine. It is heavy, stable, and vibration free. There were a few issues with our demo, but we spoke to Delta and all have been corrected in the full production version.
We did not take it easy on this lathe either. The only thing we were able to "break" was the 8amp breaker that came with it originall. We have since replaced it with a 10 amp breaker supplied by delta and no worries.
I would put this lathe, with the bed extension, up against many of the currently available 12" lathes...Mini or full size. Several of our members have put off purchasing full size lathes waiting for this to come out.
I will say that the 3/4 hp motor is not all that. I forget how many amps it draws but I would like to see 1 hp on both models.
Anyone who is attending the Woodworking show in Somerset, NJ in two weeks will be able to see this lathe at the Hudson Valley Woodturner's booth. Anyone with specific questions please let me know.
