>Santa brought quite a few tools and accessories this year.
Am primarily a "born again" turner who had not been in front of a lathe in 50 years. Received this Craftsman Band Saw for Xmas and had only used it for rounding bowl blanks which was no problem. Today I tried to do some resawing and can not get this saw to cut a straight line. Not sure what the reason. Tried tightening the tension on the blade, and adjusting the guide wheels to no avail.
Sometimes Bandsaws can be pretty finicky. Even after all you can do they still just won't follow a straight line. After you've done all you can do as far as tuning, blades, etc you have to let the saw follow the line it wants to follow. With a piece of scrap, mark a line down the center on the edge. Start cutting (without a fence), follwing the line. About half way through the cut, stop, turn the saw off, and note the position of the board on the table, and without moving the board make a pencil mark on the table. This is called "drift". Finish the cut and with another piece of scrap prepare to make another cut. This time position a fence on the table lined up with the mark you made on the first cut. Clamp the fence to table. With your 2nd piece begin the cut using the fence as your guide. You "should" be able to get a decent cut.
>Aside from what Ray said, your re-saw fence should have a convex curve, center of curve closest to cutting teeth. This lets you guide and adjust as you follow the pencil line you scribed for resawing. There's books and films that explain it better, if you can't follow what I said.
Does the blade pull consistently to one side or does it wander left and right down the cut? Does it cut straight up and down or does it bow vertically?
The book in the link below helped me quite a bit to get my 14" bandsaw in shape. Proper tension is important - I ended up buying a tension meter to help. Wheel alignment may help. Proper blade is important - a blade with too many teeth per inch will have trouble in thick wood. Specialized resaw blades are available for example the Woodslicer from Highland Woodworking or the Bladerunner from Iturra Design. A sharp blade is important.
There are two basic ways to resaw. One is to place your wood against the fence. This requires the drift adjustment Ray mentioned. The second is to draw a line on the board and use a single point guide such as arkie described. This doesn't require drift adjustment since you guide the cut to to the line.
There are a few Woodcentral articles that may be useful, including this one:
