>I'm looking for some advice or hearing your experiences about spraying lacquer in cold temperatures....
I usually finish most of my "shiny" work with sprayed lacquer (Beheln's Pre-cat in spray cans), and would like to know if others have any experience about spraying lacquer in temperatures between freezing and 50 degrees Fahrenheit. Does this work for anyone?
I realize that lacquers are 'solvent evaporative' finishes, and that at lower temperatures the rate of evaporation will be markedly slowed, but are there other changes or factors to consider if "spraying cold". Blushing might be a consideration, but in cold air, humidities are likely lower than in summer, so this might not be an issue (I rarely get blushing anyhow, even spraying on high RH days of July and August). As long as the solvent softens and "grabs" the finish beneath it, and thin coats are applied, it seems as though lacquer application might proceed "normally" at lower temps, but at a much slower rate... am I way-off here?
Does anyone have any experience spraying lacquer in cold temperatures? Advice?
>The only success I have had with lacquer in cold temperatures is that the lacquer, the propellant, and the work all have to be at a reasonable temperature of at least 60-degrees. The room can be cold, so long as those three conditions are met. That means using either a spray can or an air tank that can be taken in the house and warmed up to 60 degrees. After that, the fresh sprayed surface can be allowed to evaporate and cure in the cold. The only difference is that evaporation will take longer.
An air compressor is out at lower temperatures because because there is always the possibility of freezing ice particles out of the surrounding air as it expands through the spray gun. Ice droplets don't make for a good lacquer finish.
>I use Deft lacquer on most of my work. The problem I've had in cold temps (0-50 degrees) is the orange peel appearance. But as Russ has already said, that is usually resolved by keeping the spray can and the piece to be sprayed indoors until they've warmed to room temp. But I've never noticed the drying time to be much slower in the cold. At any temp I can usually handle it within 30 minutes.
>At the segmented turners symposium in Indianapolis a finishing pro recommended heating the spray can in a crock-pot on the low setting. Also recommended Watco lacquer - higher solids content.
>I cannot think that heating a spray-can of any kind of finish is going to lead anywhere good. Every aerosal-type can I have ever seen states very clearly not to expose it to a heating element...and a crock-pot, even on low, would qualify in my mind. Besides, there is no need to do this. Bring the can inside for a few hours as has been said before.
>I spray nearly 100 gallons of Deft every year and have about 2 months of cold weather to deal with. Not frigid cold like some of you guys deal with but days in the 30s where the shop temps are around 50 or so.
Orange peel is a problem only if I get too heavy with a coat and blushing is rarely a problem but if it happens, it's usually because I've rushed the second (or third or fourth) coat.
Knowing this, I allow extra time for drying and I make sure I'm laying an even, not-too-thick coat.
In 'regular' weather, I typically do 3 coats. In cold weather, I cut the weight of the coat and lay on a 4th.
>Like some of the others, I spray Deft from a spray can for some objects. I don't spray unless temperatures are high enough to warm my shop to 60 to 70 degrees. At lower temps, the Deft orange-peels and does not flow out well. I bring both the object to be sprayed and the spray can into the house for several hours prior to finishing.
One other very important caveat that no one else has mentioned, you do not want to spray an object that is in the process of "warming". As a wood object warms, any air trapped within the wood expands, seeps through the pores and can cause bubbles to appear in the finish. It is better to have the object in the process of "cooling", and bubbles will not be a problem. Better yet is to have the object to be finished, spray can and shop in equilibrium at approximately 70 degrees.
Spraying at lower temperatures is risky. I have had some successes with low temp spray finishing, but also many failures. I usually take the safe route and switch to Watco oil or some other wipe-on finish until the temperatures rise sufficiently.
>It is not OK to heat a spray can of paint or finish. The guy who said it is no "expert". I would call him a "Damn Fool".
This is dangerous. Heating spray cans is what makes them explode. At the worst, an exploding spray can will kill you or cause serious injury if you are too close to the explosion. At the least, you will have one Helluva mess to clean up. In either case, you will never do it again.
