Sorby Pro Edge? *LINK*
Dave Anderson (PacNW)
>Has any one seen or used one of these?
Sorby Pro edge
Re: Sorby Pro Edge? *LINK*
Re: Sorby Pro Edge?
don lewonczyk
>I have one and it works very well, pricey for sure but it is well made and hasn't given me any problems. I think Ron Mckinny has one and about a year ago he wrote something about it here. It's packed real well for shipping also so you don't have to worry so much about it getting damaged in shipping. DonL
Re: Sorby Pro Edge?
keith zimmerman, Normal IL
>I have one and it works very well. My only problem with it so far is that I haven't been able to recreate the long side grinds on my bowl gouge. It very well for the Sorby style fingernail grinds as they come from the factory, but not as easy with longer sides. Once I figure that out, it will replace my Wolverine.
Sharpening every other tool is very simple and very straight forward.
Although a pricey setup, it is very sturdy and compact and will do the job very well.
keithz
Sorby Pro Edge-Long
Ron McKinley
>I've had mine just about a year now and after working out my own way of using it I really like it. It's kind of like a Shopsmith in that it does just about everything but not very conveniently. To sharpen finger-nail gouges the table must be removed and then reinstalled for sharpening skews and scrapers. I suggested to Sorby that if they increased the length of the "boss", a cylindrical piece of metal that is used to mount the finger-nail gouge sharpening attachment, the table wouldn't have to be removed. They blew that one off. I keep thinking I will get a machinist to make me a longer piece but so far haven't gotten around to it. One other thing: When using the finger-nail attachment you're probably going to grind off part of the jig trying to get really swept-back wings, but, I've ground off the sides of my Vari-Grind jig too!
I've also looked at the possibility of mounting it on a platform so I can use the Wolverine System with it to eliminate that problem and keep the table in place but so far haven't gotten around to it. I would have to come up with a way to raise the "cups" of the slider arms like John Lucas has done for some of his work. I've really been shy of "roundtuits" this past year!
The skew jig isn't very effective unless your skew's handle is removable because the handle hits the motor on the left side so I just rest my hand on the table and sharpen freehand. If you get it right it only takes a second on each side. Scrapers are no problem. The universal sliding jig for sharpening spindle roughing gouges is too narrow for mine (1 1/4") but works fine for smaller gouges and works fine for traditional bowl gouges (without the finger-nail grind). Again, resting my hand on the table and free-handing works even better than a jig.
It sharpens flat-work chisels with no problems and for the first time ever all my flatwork chisels are sharp!
Now for the best part: No spinning wheels and the mess that goes with them. Sharpening on a belt is much safer than grinding wheels and the belt can be cleaned with a rubber block. Dust/grit collection is simple. I cut off the side of a small plastic bin and slip it under the bottom of the belt and that gets about 98% of it.
In addition I like the flat grind I get versus the hollow-grind. Most prefer the hollow grind but the flat grind works best for me. (I believe Wally Dickerman in AZ sharpens on a belt sander.)
This machine is built like the proverbial battleship and should last a lifetime. Belts are much cheaper than grinding wheels and can be changed quickly and they're never out-of-balance. All in all, I like it and would buy it again........Ron
Re: Sorby Pro Edge?Thanks to all for Responding
