Apple bowl
Apple bowl
Apple bowl
>I decided to do a simple photo shoot to show that you don't need high quality equipment to do a photo shoot. This is an apple bowl I just turned. The clock in the earlier post was also shot on this setup.
This isn't a great photo. There are too many highlights and double shadows. However for our purposes here which is to simply show off the work it's a decent photo. The color is correct and it's mostly in focus. It could use some more depth of field. I shot this at f8. I probably should have used at least f16.
Re: Apple bowl
Re: Apple bowl- photo set
>Here is my setup. I used the stove light for the "fill" and a table lamp for the main light. Since I couldn't move the stove light I moved the table lamp back until the shadow caused by this light was less intense.
I set the camera to the tungsten setting and used a tripod. Since I was using a gray background I didn't have to adjust the exposure. I used the reading the camera thought was correct. The background is a Thunder gray seamless scrap cut from a used 4 foot background.
The photo was very slightly yellow due to the household lights not matching the tungsten setting. It was close enough that it only needed a very slight adjustment in photoshop.
Re: Apple bowl
Re: Here's another very basic.........
Jamie D
>......photo set-up using only the overhead fluorescent fixture. Backdrop is a vinyl window shade, and it's very easily stored by simply rolling it up. Total extra cost about $5 for the shade.
Re: Apple bowl
Now you've got 2 easy choices-show us some work :)
>As you can tell the lighting and set up isn't difficult. It's more important to get the color right and to have the piece in focus. If your camera has white balance ajustments, give them a try. Sometimes the A setting still works better when you use solid gray or white backgrounds.
Use a tripod or some good way to steady the camera. Ideally shoot the image and download it before taking your assembly down. That way if the piece isn't sharp or underexposed you can try again.
Re: Apple bowl
chair studio
That's some great advice. I don't photograph often but when I do I take over the dining room table, shoot everything, then go download and review before I tear down the setup. When I tore it down before checking the photos I spent more time saying things like "rats". (Years ago when I used film cameras and darkroom I said "rats" even more often.)
Before I built a little cloth-covered light box, I used my dining room chair photo studio, photo attached. I would turn the chair to catch the best light from the windows, or use a couple of lamps at night.
Re: Apple bowl
Re: chair studio
>A sample from the dining room photo studio. Needed a bit more light in the front but the shadows are nice.
