A much better day
MFoster
>Well I spent a good day in the shop today. I first went to check out the compressor. I turned it on this morning and it cranked right up, but still no air in the lines. That seemed odd, so I went down to check it out. Looked at the pressure guage on the tank (couldn't see it last night, too dark) at it was at 120. Hmmm! The room was cold, (1 F this AM) but it has a grill in the ceiling that opens into the shop. I built this purposely to allow warm air from the dust collector in the basement to return to the shop after being filtered so I don't blow all of my heated shop air outside. So I turned on the dust collector and went for a walk with the dogs. This did the trick. Must have had some water in the air line from the compressor that leads to the shop right at the tank. Seems odd that water collected here since it should drip to the bottom of the tank. Easy fix.
Came back and spent some time doing some minor milling to get my new quill installed on the tailstock. Bingo! Another problem solved. I gave it a real workout and found that the vibration I had is gone. Not sure if the solution was because of the morse taper (still my best guess) or the play I had with the quill in it's housing. The new quill fit much better with almost no play.
Then I spent some time with various reverse turning jigs and got the large segmented form turned, sanded and off the lathe. I still need to finish it, but will post a pic once that is done.
Life is good again.
Mike
