Pen turning question
Sean Troy
>Hello all, is there anything special that needs to be done to dryed corn cobs before they can be turned to pen blanks? Thanks for any info. Sean
Sean Troy
Re: Pen turning question
Jennifer@Indy.USA
>Well from an Indiana Corn Gal, I think they have to be soaked in CA glue first. Either that or epoxy. Otherwise you'll get a bunch or corny dust.
I've never made a corn cob pen, but the blanks I've seen are always soaked in a stabilizer of some sort.
Jen
Sam Scalzo
>Sean, I tried turning corn cobs and did not have any luck. I think maybe they need to be soaked in something. I have three left but haven't done anything with them. Maybe I will try CA GLUE.
I have turned a lot of pens but never had the problem that I had with the corn cobs. Sam
fbearman
>The commercially available corn cob blanks are impregnated with an acrylic-type formulation, seemingly in a process similar to the stabilized wood blanks, and turn very nicely. Makes for an interesting pen.
Happy New Year to all - I haven't posted anything at all in a long time, but I wouldn't miss stopping by to read.
Fred
Sean Troy
>Thanks all, thats what I was thinking. I'll have to get some for my girls.
Chip in Plano
>I tried to make pens using the commercially available ones. Maybe you can develop your process better because I have been unsuccessful so far with the commercial ones.
Here my 2 cents:
.you need to be making these a fat/grande pen. Forget 7mm and O size.
.the best cob will have a small central soft core. I found the narrower tip end to be the best candidate not the larger stalk end.
.You need to drill it out the soft core as it is weak and will compromise the pen blank when glued to the tube.
.Adding thin CA to the drill hole will help to strengthen it.
.Turn lightly. Sharpen the skew often and add CA, repeat continously.
All my attempts ended with a chunk of the blank separating from the tube.
I hope your cob stabilization/preparation is better than the commercial ones. I have one blank left. I'd return it but I cannot find the receipt.
fbearman
>I get my corn cob blanks from a commercial operation in Wisconsin, and their process involves using pressure to get a good fill with the resin. I have had no problems at all turning their blanks. They also offer a number of other services that are of interest to pen turners, including stabilizing your wood for you in small quantities (such as if you cut down a tree with burls, cut some of the burls into pen blanks, and you want them stabilized, or you have some historic wood that you want stabilized). If you want their name and contact info let me know.
Fred
Sean Troy
>Yes please, that would be great info to have handy. thanks, Sean
just use good old cobs (LONG INSTRUCTIONS)
Dick Coers
>I'm going to go against the common thread here. I spend a lot of time in the field finding small diameter cobs, then with a little CA at an appropriate times, I have turned at least 35 corn cob pens. I use the euro kits, 7mm tubes, with great success.
My technique;
1) Look for cobs with the core slightly less than 7mm at the small end.
2) If the soft core is larger than 7mm, I use a long brass tube instead of a drill to take out a plug of material. A drill will wallow around in the soft core and oversize the hole.
3) Use med CA to glue in the brass tube, and move it around a lot when inserting to get good glue spread.
4) Soak the ends of the cobs with thin CA after the tube is glued in. The ends are the most fragile during turning.
5) Turn the cobs about 3/32 oversize and remove from the mandrel. Slide the blanks on a small wood dowel and soak the entire cob with thin CA. Let that dry at least 20 minutes. I usually turn a half dozen pens at a time, so waiting is not a problem. The cobs are really porous and the thin CA will soak all the way to the tube.
6) Remount and final turn. I use a skew with light cuts. If you are using a scraper or gouge for turning pens, learn to use a skew for more success with cobs.
7) Ocassionaly I need to fill some kernel pockets. Use Med. CA to fill and turn flush.
8) Final finish is three light coats of med. CA, sanded down and polished to 12000 micromesh, then plastic polish.
I"ll retry to add some photos, it dumped out the first time for oversize photos and I don't want to retype all this again.
pen pics NM
Dick Coers
Re: just use good old cobs (LONG INSTRUCTIONS)
Sean Troy
>I have plenty of cobs left over from feeding the critters my girls always seem to adopt. It's worth a try. thank you
fbearman
>Have sent you an e-mail.
Fred
Russ Fairfield
>I have made a few corn cob pens, maybe 15 or so, and they were all made from the dry cobs that are sold as squirrel food at WalMart. They worked fine. With enough CA glue, you can turn anything.
I Have A Question
Barbara Gill, Remlik VA
>Is the economy of processing the cobs better than just buying the stabilized cob blank? It seems as if with the time and CA it might not be.
Re: I Have A Question
Sean Troy
>Probably not but might be fun for the girls to do the process so they can be more involved with the final product.
Russ Fairfield
>Depending on whose CA glue you use, the cost per corn cob will be $5 worth of CA glue, at the most, or about the same cost as buying them stabilized. The advantage is that I can pick a good cob with a small pith and tiny kernels, and not depend on someone else doing that for me.
Larry Gottlieb
>I think that I turned the first corn cob pen several years ago.I made a modified slimline with a walnut center band. When I posted a photo, very few people were able to identify it.
What I did and have repeated was to use a dry corn cob. After the hole is drilled, dribble thin CA into the blank as you rotate it.
I used polyurethane glue to glue the tubes.
As you turn, take light cuts and continue to use CA. (I never used the amount that Russ indicated)
The finish was CA.
Larry
Dick Coers
>I doubt if I use $1 worth of CA. I also use waxy corn cobs. They are white on the outside, but have a stronger red on the inside. Some red cobs I have tried have a washed out color. Using local cobs is also part of my marketing. I tell people I pick them up, and this ties in to local artisan, local product.
