>I have a Rikon mini lathe and when I put steb centers in both the headstock and tailstock they line up perfectly. When I turn a piece round and if I switch the piece end for end I have to true the piece up again. Each time I switch it end for end I have to true it up again is this normal? Thanks for any help.
>The points of your centers could meet even if the spindle and tail stock were at 90 degree to each other. Does the face of the spindle and ram butt true? They are not very wide but if things are realy off the faces may not make full contact.
If you had a double ended taper shaft to fit into your headstock and tailstock you would find the axis are probably not on the same centerline.
Don't know if your lathe is bolted down but these little lathes are not that ridged. You could have the bed out of level or in a twist from end to end.
Not sure how bad your out of round is if you turn a large diameter long spindle flipped end to end, so not sure how critical it is to align better.
