200+ woodworking book reviews
Not meant to turn tonight
MFoster
>So I received my new quill for the Woodfast and thought I would use it tonight to turn the foot on the segmented piece I'm working on. I put the Oneway center into it, and it seems to fit perfectly. Put it into the tailstock, and I find that the keyway that keeps the quill from rotating binds on the Sellock pin that is supposed to fit into the keyway. Since this is a spring type pin, I just forced the quill on for now (quill does not feed with the taistock screw) I already know how I will fix this but I wanted to turn.
So I needed a jam fit lid for the open form because my foot will be 4" and I have been using a 6" faceplate. This is a segmented form, and I used a waste block to mount the foot, I can take the outer screws out of the faceplate and turn down the foot to the final form. I don't think it will, but I want to be sure that if the form delaminates from the waste block, it won't hit the floor. My answer to that is use my bowl steady and the tailstock with the jam fit lid. If the form comes off the faceplate, I should be fine. So I'm fitting the lid (trial and error) and had set the piece down on the floor balanced on the headstock end of the faceplate. I was going to get a marker and, you guessed it, I knocked the piece over. The rim hit the lathe and put a decent dent in it. A few choice words seemed appropriate. Once I regained my composure I inspected the dent and realized it wasn't that bad. Put it back on the lathe and turned out the dent. Started sanding it back up to 800, and went to blast off the dust between grits and found I had no air. I had turned on the compressor when I went in the shop and heard it go (it is in a basement closet with the cyclone), but no pressure at all. Went down to the compressor and found that it is plugged in, the switch is on and the reset button did nothing. More choice words and I decided to give it up for tonight. Just one of those nights.
So, it's 4 degrees outside right now, and I have a feeling that may be part of my problem with the compressor. I am a little baffled that hitting the reset on the motor would not get the compressor to at least try to go. It's like it wasn't plugged in at all. This is a 5 HP Oil compressor. I will do some troubleshooting tomorrow, but thought someone here may have some ideas. I didn't try to plug it into alternative outlet, but I did check the breaker box and the breaker did not trip. I am pretty sure the oil level is OK, but will check that again tomorrow, just too cold and dark to do it tonight. Any thoughts?
Sorry for the rant, just had to vent.
Mike
Re: Not meant to turn tonight
Bill McWhirter
>You are an American and a wood turner. The dink was "design opportunity." The compressor is giving you an "upgrade opportunity." Go get that 120 gal. Ingersoll-Rand that you deserve.
Seriously, sorry for your problem. I can identify with you. My powermatic just quit at 4:30 yesterday and, of course, WMH Toolgroup is closed till Monday. I can not use this as an "upgrade opportunity" since the previous lathe, a Jet 1642, did exactly the same thing last New Years Eve, and I really don't want anything bigger. I will not turn next new years eve.
On the positive side, this will be a much needed "shop cleaning opportunity." Also, I called the guy I order the lathe from and he is off visiting in-laws. He had me check a couple of things to no avail. But as luck would have it, he happens to be passing through my town on his way home today and said he would be happy to stop by and give it a look.
I look forward to meeting him since I have only talked with him on the phone. I have met some of the nicest people as a result of my woodworking. If anyone is about to buy a Jet or Powermatic, I will be happy to give you this guys number. He gives a good price and has it drop-shipped from WMH.
Have a happy and safe 2009!
>Bummer Mike. Had that problem last year. A new compressor was not an option at that time so I bought a new regulator that cost 1/3 as much as the whole compressor. At least now I can sell this one when I get the new used I bought installed. did you check for an overheat switch on the compressor. I had one of those go bad. I wired around it until I could buy a new one.
You will be fine with a jam chuck and steady rest if it's a 3 or 4 wheel version. I've done that several times on forms that were to fragile to really jam chuck. I make a form that fits the lip just barely touching, then I bring up the tailstock to push against the piece and tape the piece to the jam chuck with lots of blue painters tape.
If you turn to the point of completely removing the tailstock it may not run completely true at this point so turn as much of the foot as possible before removing the tailstock. That last little 3/4" or so can then be turned away. Oh I almost forgot but it's probably obvious. Put the steady on the fattest part of the vessel.
Hope today is better. Have a great New Year.
don lewonczyk
>Check your breaker first, my heat pump quit on me last week and as usual in the dark, I checked the breaker and it was fine, shut it off and it reset fine. Went thru everything else that could have caused it and that was fine but no power to the transformer, went back to the breacker and only one lead was hot, nothing on the other. Replaced the breaker and worked fine. My compressor in the barn shop won't start in cold weather, it has oil lubed so I shut the breaker on and off several times and it finally kicks on, im bringing my old oilless to the barn and use it in cold temps, who has time for the bulls--t when your in a hurry. Luck, DonL
GalenV
>When you say the breaker did not trip I assume you shut the breaker off and reset it. Sometimes the breaker kicks out but does not trip the handle on the outside or moves just enough you think it is on.
Then check the lines for voltage out of the breaker as it could be bad.
If your compressor has a low oil pressure switch it may have tripped if the oil is cold and thick. The oil pressure did not build fast enough when it first started, since you said it ran once. Does it have a manual reset to insure you check for oil if it trips.
Just have to narrow trouble down. Check voltage at you plug and then at pressure switch. At the same time look for arcing or burned contacts.
Hope you have warmer weather to trouble shoot.
Galen
