Re: finish over color?
Brian Hahn in SW Wisconsin
>The problem with markers like Sharpie and Prismacolor is that the colors are soluble in most solvents. I seal the colors first with a light spray coat of Krylon Fixatif. The Fixatif won't make the colors bleed. Then it is safe to use the finish of your choice. I usually use a spray can of lacquer (Deft) or clear acrylic (Krylon), but I've successfully used a number of other spray finishes.
Inks and watercolors don't have a water-proof binder and need to be sealed with a light spray coat of a solvent-based finish like lacquer. I used a water-based sanding sealer once and that added some "interesting features" to the design.
Airbrush and artist acrylic colors are pigments dispersed in an acrylic medium. Once dry, they can be top coated with anything.
