>I need to fill some shrinkage cracks in a cherry bowl. Any tips or suggestions on best way to do it? What is the best adhesive to use? I would like to accentuate the cracks rather than hide them. Any details about the process would be appreciated.
>While I have no idea what your cherry bowl looks like, one of my favorite fillers is instant coffee (powder) and thin CA. It can blend in as a streak or bark inclusion. I larger openings, I often mix in some dry coffee grounds to add a little texture and make the inclusion more realistic.
>My favorite filler for Cherry is Lacey Inlace. Inlace is a resin and Lacey is the color I like for Cherry. It's kind of a turquoise and granite sort of look. It really highlights the Cherry. I get it from Turtlefeathers.net
>I'm with John. I use Inlace but I use the Turquoise. I also will use epoxy and add color tinting and sometimes adding either coffee grounds or metal shavings from the key grinder from the local home store. Thick CA will work buy epoxy gives you a longer open working time.
>I went to a shop that made keys and got some of the filings. Not what I expected. They were sort of dull brass with silver (Chrome?) mixed in. And they are SHARP. They will get stuck on your skin even if you are careful.
I made my own brass filings by taking a coarse file to a big brass screw. Took a while (five minutes?) but they were brighter and prettier. Put a piece of paper on a scrap block of wood and drive the screw through it. The paper catches the filings and you can use it to funnel them into a small container. Use epoxy or medium CA.
>Barry, I like to fill small narrow cracks with copper powder (craft supply) and CA glue. I fill the crack and than add the ca glue. The powder shrinks and you will have to fill it maybe two or three times but it is fast and works well. Before I fill any cracks with anything using CA glue I first give it a shot of lacquor (airosol can)around the crack to seal the surrounding wood so the ca glue wont stain it. You can also get the powder in brass and pewter which I have used but I like the copper. I have mixed some powder with epoxy and filled cracks but it doesnt come out as nice as with the ca glue.
>I saw a tip on making copper powder to fill cracks. You take a piece of copper pipe and hold it against the disc sander with a piece of paper underneath.
Then toss the pipe across the room because it gets extremely hot, extremely quick. Pick up the pipe with gloves and try again. This time it worked great.
As was mentioned above if you use a course file you bet larger shavings.
>I get the shaveings from HD and use a cheap coffee grinder to grind them into a powder. If you don't grind them into a powder you will spend the rest of the day picking little shardes of brass out of your fingers.
PS. Make sure you use safety glasses when useing key shaveings. You don't want those things in your eye ball.
>Thanks guys for all the tips. Your speedy responses were much appreciated. I tried turquoise powder with Special T Hotstuff CA, and it turned out pretty well. I had to make multiple applications, but the final results were pretty good. I may try epoxy next time. By the way, the bowl was hand carved and not turnedon a lathe.
>I never thought about it but I guess a powder would be easier. I do like the realistic effect of shavings. Are you using an electric coffee bean grinder or something else?
If so, I'd better buy the wife a new one before I trash the old one.
